2813 Disassembly
KyleP88
Evening everybody.
How easy is it to change the date wheel on a 2813 movement? Has anybody got experience, pictures of the disassembly or any tips to help me along the way? I know there cheap and throwaway but I'm doing a favour for a friend.
Thank you
Kyle
15 hours ago, KyleP88 said:
Evening everybody.
Thank you
Kyle
I guess it is a DG2813 movement you mean? Look for Miyota 8200,8215 as that is the original? DG2813 is a clone.
Could be two things wrong if the date doesn't work? There is a little spring that can unhock or date wheel broken?
http://seikoholics.yuku.com/topic/109/Inside-the-Miyota-8200A
Depends how much experience you have in tinkering with watches?
Edited by rogart63
There are also two variations of the dg2813 out there regarding the date function.
And this is the other one. The wheel is mounted with a circlip which can break easily.
Can not comment on this type. I have it but i did not needed to disassemble it.
The other one is pretty straightforward. Moreower, as i remember it was easy to reassemble, since all springs were secured with screws so no chance to fly away parts.
Edited by szbalogh
  • Similar Content
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
