I'm looking for a little feedback regarding cracks in jewels- specifically hairline cracks.  I'm working on a piece now that has a hairline crack in the upper balance jewel.  Under the microscope the crack doesn't appear to structurally change the pivot hole- that is to say the hole is still nice and round although the crack does extend from the hole to the edge of the jewel, however, the amplitude drops significantly (~80 degrees) when the watch is placed in the crown down position and the watch slows also by about a minute and a half per day.  So the question is, can this hairline crack be causing the loss of amplitude and time?
I should note that I've poised the balance and inspected the pivots which are round and straight so I'm starting to think the crack is the culprit.  I won't know for certain until the replacement jewel is fitted but if anyone has experience to share I'd love to hear it.
Well I forgot to upload a picture until today but better late than never I suppose!
I've ordered the replacement jewel and am feeling a lot better about it as close inspection has revealed two cracks and also a nice divot where the pivot collided with the jewel at some point int he past.
Out of interest, have you had a good look at the pallet lever jewels (the escape wheel ones, not the pivot ones). I have seen a few Pierce 134s with chipped lever jewels - not sure if they get a particularly hard ride or just been unlucky.
Oddly I haven't seen damaged pallet jewels yet on a Pierce.  In my previous experience I've noticed quite a few damaged jewels on the chronograph bridges though.  Not sure why that's the case but I believe I've replaced three of them this year.
This Pierce has been a real treat.  A cracked center jewel and a chipped upper balance cap jewel in addition to the above mentioned pivot jewel.  Luckily for me the cap jewel is only chipped on the topside.  Who knows how that happens?  :huh:
Oh and replacing the center jewel was a fun endeavor.  I had to fabricate a punch for my Seitz tool in order remove the damaged jewel as it was set in the bottom of the minute pinion post and could only be pushed out from the dial side.
i'm glad i read this thread. i was going to post a question about my seiko 7s26, but this might be the answer. i serviced it last week and got it to running fine - as long as it is dial down. when i turn it right side up or on it's side, it slows to a crawl or stops completely. i will have a look at the jewels to see if they are the culprit.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
