Antique / old watch repairs.
Hiya,
I currently use a watch repairer who is awesome at new watches and watches around 20 years old or so, but anything antique like pocket watches or early wristwatches they always return with 'parts worn/obsolete'. I'm not even sure they inspect the watches before they send them back.
Is there anyone in the UK that can tackle these at all that you could recommend?
Thank you,
Alan.
Sent from my HTC One M9 using Tapatalk
I can imagine that to be a problem sure, and I can understand that the company wouldn't just strip a watch just to find out that it can't be done economically. However it would be nice to find someone who tackles the older pieces just so I can give the opportunity to make their own mind up.
One day I'll teach myself how to do it, which is the aim. [emoji106]
If you live in the UK, get in touch with the B H I look on there web site email them tell them what you have and where you live, they will get back are recommend someone who will be able to help you.
Thank you. I did a bit of research and found they have a good list of repairers. Going to pop them an email, be nice to use one local.
Cheers again for the advice.
Alan.
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
