Strange timegrapher graph
Usually, when coils touch each other or there is banking, the rate increases.
In your case the rate decreases. I think there is a problem with the regulator pins - the hairspring is not centered between them, or even rests on one of the regulator pins - and when the amplitude marginally increases, the equivalent HS length increases, because it will not touch the regulator pin.
Also try a demagnetization.
Edited by matabog
Can you do a longer term capture? I'm only starting to dig into the timegraph troubleshooting but my initial thought is that it could be a defect in one of the train wheels? Then I guess it would happen on all positions.... hmmm... maybe debris that affects only on that position? Interesting! I hope you get to the bottom if it. Good luck!
Cheers!
51 minutes ago, rodabod said:
How does the amplitude vary when the rate suddenly changes?
Good point, which I forgot to mention - the amplitude doesn't react into these drops in any way. Amplitude goes dial down around 274-278 degrees when fully wound, even if the beat drops.
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
