I'am just replacing the battery and seals in a Tag Heuer 1000, didnt look too much like a hard job until I realised the internal crown seal has turned to a tar like matter..
Looking around google it seems lots of people suggest a new crown/stem but this seems like overkill for what should be a small nitrile o-ring replacement.
So - what size o-ring should I use and how do I clean out the broken down old seal? Checking with my vernier the crown tube is 2.6mm so I was thinking a 2.50 x 0.50 x 3.50?
Would really appreciate some help on sizing this seal and removing the old one..:)
Clean out the old one with acetone. Usually works if it's in the crown? . Can be really difficult sometimes to get the right size o-ring.
Thanks :thumbsu:,
I have got most of the old seal out now and will be ordering from Cousin's soon so any ideas on correct size of new seal would be amazing or is it a measure best I can and guesstimate!
I measured the size of a crown gasket for a Swiss watch with a vernier caliper. Luckily Cousins had an exact replacement, under "waterproof crowns".
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
