Pocket watch to Wristwatch.
Ruby2
Hi All
If I get a pocket watch with a Unitas 6497 movement, can I put the movement from the pocket watch in to a wristwatch case (that is designed for the 6497)?
The crown is obviously on the top of the pocket watch, but on the 3 position on the Wristwatch case, so can the movement be fitted 90 degrees to the right and the dial still be the correct orientation?
Im purchasing the pocket watch for my first watch to learn to strip-rebuild, but I thought it'd be fun to turn it into a wristwatch too ;-)
cheers
Richard
if you had a choice which you really want to use is a 6498. Basically identical almost sort of to the 6497 except where the secondhand is in relationship to the stem. So as your familiar the 6497 has the crown of the 12 o'clock position the secondhand at the 6 o'clock position. The 6498 has the crown at the 3 o'clock position and the secondhand at the 6 o'clock position in other words it will go in your wrist watch case and it will look like a wristwatch. so typically the 6498 movement would be found in a hunter pocket watch which typically has a spring lid.
5 hours ago, Watchtime said:
Should not be a problem, but you will have to change  dails. It is a great movement for learning about mechanical watches. Here in the Lowlands the school for watchmakers starts with a 6497.
Cheers
That's great.
Ive just dropped on a lovely Limit pocket watch with a very clean Eta 6497 movement in it.
Im not sure if it's too nice to take apart and use as a wrist watch it seems to be mint.
I managed to get it for £85 inc postage too.
Get in!
Ahhhh I see.
Ive just made a pocket watch purchase with a Eta 6497. It looks far too nice to take to bits for the movement.
So with your info (many thanks for that!) I shall now go out and look for a 6498.
Cheers.
4 hours ago, dadistic said:
No worries! If you take apart the pocket watch, you can always put it back together again if you want to. I've hung on to the bits from a Colibri watch that I did the same thing with.
You can find suitable dials here for both the 6497 and 6498. Cases, too.
6487 6498 Dials
Have Fun!
Hi
Many Thanks for that.
I see there are some versions of the dials that have the sub seconds at the 6 position.
Would this work with the pocket watch movement in its current orientation?
.....although the crown would need to be on the top like a Anonimo Militare :-)
i gather they don't make cases with the crown in that position?
Cheers
Richard
Hi
Coupd you answer a question for me.
Is it possible to use a 6498/6497 case with the crown in the 3oclock position and due to rotating the movement clockwise 90 degrees, then have the sub seconds at the 9 position on the dial?
Cheers
Richard
Yes, that's what you do if the movement's not made for a hunter case.
Have Fun!
    • Never seen that but yes very practical Hector
    • Welcome, Simeon! I'm into Soviet watches too (not the political system, and yes, I am able to make the distinction, unlike some). They offer amazing value for money. I like your "Big Zero" profile image. It's a true classic and I have one of those myself. I noticed that the hands aren't the original. Not that it matters a lot but here's an interesting article about the Big Zero if you haven't already seen it.
    • I was thinking will the gasket stretch at all to match the desired size.  Did i also deduce that the original gasket is thinner (0 .5mm ) than the cousins gasket ( 0.8mm )  could that just be an effect of you measuring the case for the gasket size  H  ?
    • if we look at and understand why steel becomes magnetised and unmagnetised then its possible to work out why some devices are better than others. Simpy it is a parallel alignment of atoms , electrons within a material caused by external magnetic fields. Different magnetic fields cause different alignments and non alignment of atoms. Fields by AC currents are changing atom direction approx 50 times per second ( 50hz ). As a material is drawn away from a demagging device the field is becoming progressively weaker while also changing the material's atom direction having the effect of returning their random directions ( demagnetising ) . To improve on this demagetising effect, try changing the material's orientation as it is drawn away.  Fields caused by DC currents have the most permanent magnetising effect as the currect is flowing one way only. A good demagger would produce random magnet fields and disorientation of the material's atoms.
