I think I know the answer, but I've been wrong before......
I recently overhauled a nice old pocket watch, including complete dismantling, cleaning, reassembly, and lubricating. As it happens, something wasn't quite right which necessitated completely disassembling it again (ok., so I forgot to install a component), this resolved the problem so I reassembled it, and tested it and all was fine. My question is, should I have cleaned it again once it was disassembled and then re-lubricated it?. As it happens, it's still working fine, but I'm worried that the oil may now have spread to nasty places when I disassembled then reassembled it - or am I worrying over nothing? Is there a golden rule regarding cleaning and lubricating every time you tear a movement apart?
Thanks, and cheers from snowy Edmonton.
Generally yes.
The correct way is to assemble, then oil. This way the oil is centered around the pivot nicely (as in all the watch books).
When u disassemble and then reassemble, the oil already in place will be displaced as you try to get the pivots in place.
Anil
This is what I though frankly and I will always do this from now on. I do have a further question in this regard however, namely what should I do if I install and reinstall the balance wheel, say for reducing the beat error - do I need to clean and re-oil the balance pivot jewels each time?
First of all, you need a metal being in Edmonton and the nasty cold: my oldest son is there. Second, by disassembling the watch, you have reintroduced dust and finger dirt (unless you wear finger cocks). So i would say you need to at least do a basic cleaning of the movement and then reapply the oil. The big pocket watches, 18s, I think are more tolerant to dust due to the gear size; so you might get away with just reassembling and cleaning and touching up the jewels with oil.
Sent from my GT-N5110 using Tapatalk
