Hi
I've got a pretty nice Seiko 7005 2000, a large 17 jewel automatic, that needs some attention. One of the items missing is the crown, and I'm having trouble finding a replacement. Does anyone know the part number for this models crown, and where I could get one? I've asked a seller on Ebay who has lots of Seiko crowns, but he says he doesn't have this one. Failing that, does anyone have one and can give me the dimensions of the crown, height, width/diameter etc? From the photos I've seen it's meant to sit almost flush with the case and the only gold plated ones I have sit proud. Thanks
Stephen
Cousins say the part number is 40N27NN1 - should have checked there first really. Doesn't help though as they say it is obsolete and I've not turned anything up on a quick search with that number.
There is some guy on SCWF that has a lot of crowns . Have you checked with him? BigV86 or something like that?
have you checked that cousiinsuk says right. According to jules borel you should have a crown http://cgi.julesborel.com/cgi-bin/matcgi2?ref=X\wF]bvF
I think the are more right?
If so you could use a AM crown for a 6139-6012. As they share the same crown.
If you can't find an original crown that is? I think you can?
Forget i see now that it's the gold version you are looking for?
Edited by rogart63
Thanks for your help, but I'm thoroughly confused now. Cousins have one part number, 40N27NN1, and Jules Borel have two different part numbers, 40M16MS1 and 40N27NA1 - all for the same item!
I don't think I'd order from Jules Borel anyway as last time I tried to open an account they said minimum order was $100 and then never responded further.
As you suggested I think I'll try SCWF. Thanks
Stephen
Stephen
40M16MS1 is the stainless steel version . The other 40N27NA1 is for the gold double version. The one cousinsuk have is probably a version that also work. Very similar.
I think the number is the size? 40 is 4 mm in diameter? 27 maybe the width? And the letters is which color or if it's stainless or gold and so on?
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
