Seiko 6139-6002
arkobugg
Hello Mates!!
Im working on i dial for a Seiko 6139-6002 with the golden colour dial, and want to refurbish this dial. And I need some paint that can match the existing colour.
Is there anybody that have some experience with nail polish??
Can this be used, and how to aply it to area that are 0,3mm X 0,3mm
Thanks and best
Hi arkobugg,
I usually don't retouch dials since they are very delicate. On one or two occasions I have use a very small (super small) dab of black acrylic paint on a certain type of dial as a last resort and was able to hide -- with lukewarm success -- the tiny dot on the display. Not recommended!
That said, I don't think any dial will really be able to be completely restored unless you use professional methods that, by the way, seem to be kind of well guarded.
Cheers,
Bob
On 21.10.2016 at 5:31 PM, bobm12 said:
Hi arkobugg,
Cheers,
Bob
Hi Bob, just as I thought....I know is that is a difficult task, but this dial is very rar and hard to find original. ....
Can you ore anyone else recommend someone that can do this ? here is a photo of the dial.
Thanks Armand
Nothing is wrong with it. Leave it alone, and wear it with pride.
Thanks Armand
I really have to agree with jdm,...There's nothing wrong with it . Leave it alone and wear it .
Having said that  , you seem to think this dial is rare . An original would be hard to find , but you putting make-up on it isn't going to improve the value .  I just saw 3 AM gold colored dials for sale on ebay going from $14+ to $35 + , and yours looks as good or better than those .
I really decided to input my 2 cents worth into this post because having a few vintage Seiko chronometers , I wouldn't consider a Pogue "rare" because there are so many on the market with the sellers all claiming them to be rare , then putting an unrealistic "buy it now price " in an effort to support the "rare" discription .
I would consider a Pogue dial that was original with the words ," Water70Resist " , to be scarce , "Water70Proof"  to be even scarcer , and the first Pogues with the notched case at the crown position to be Rare .
In any case I think yours looks good enough to wear just as it is .  I have a gold dial Pogue , and  it is good looking .
Aloha ,
Louis
    • I’ve tried everything using both my blue and donut demag units.  I’ve even tried beating them with a steel hammer 🙂   im now trying heating them over gas flame — if that doesn’t work …..
    • The 110v supply could be problem with the blue one. Have you tried moving the piece to demag through different orientations manually as its drawn away ? As Nev quoted the magnetic fields of the demag have to overcome those of the steel.
    • Thank you Marc! I re ran the TG. First I went ahead and checked the balance jewel on the regulator and it was bone dry. I cleaned and oiled it, not without some drama including pinging the capstone and searching my bench with a black light for 30 minutes and finally shone it on my face and looked in the mirror only to find it on my left cheek in my 2 day growth! Back in and on the Grapher we are at 275. However significant drop in DD (234) and CR (190 edited) positions tells me it's time for a complete cleaning and oiling.
    • My $12 blue one seems to work well enough for movements out of case. However for  tools with greater mass, such as my small and large anvils which are highly magnetized the blue unit is useless.   For whatever reason, my high current K&D donut unit just doesn’t seem to work, regardless of my attempts to use it as instructed in this thread (magnetizes stuff fine so I know it is energized).
    • PUW1563 is the day/date version of the 1561 (date only). I have just measured a 1561 using the old "blob of paint on the rim" technique to determine the actual amplitude by observation, and then putting it on my TG and adjusting the TG lift angle until the displayed amplitude matches the observed amplitude. I get 48°. Not a million miles away but it will have overstated the amplitude by about 20° with the TG set to 52° (I tried that as well for completeness). So with a more appropriate lift angle set on your TG you would have got an amplitude reading of about 240°.
