Dulux chronograph
Daveb
just received this one in the post, not sure if I have made an expensive mistake, all I know about it is it's a Dulux chronograph, it's missing the crown and was sold as untested. I think it has a Landeron movement but I can't work out how to remove the back and I'm too scared to force it. It has gold markers but rose gold coloured hands except the sub seconds which looks like a blued hand. Not sure what colour the hands are supposed to be. The case is covered in green from the brass strap pins but should come off easily. The good thing is when I give it a little shake the sub seconds ticks for a couple of seconds and the chrono pushers click nicely. The glass is scratched and the chrome isn't brilliant. What do you think? Any info would be appreciated. I won't even attempt to take the movement apart, that would be a very big mistake at the moment. Sorry about the pic I had to use my phone as I can't seem to upload pics on here from the camera. Cheers, Dave.
25 minutes ago, Cad101 said:
A pic of the back would be nice or it could be a front loader does it have a removable bezel on the front i cant tell from your pic.
I will take one when I get back from work, it looks like a snap on but there are no recesses or lips, the bezel does look more (roomy).
15 minutes ago, StuartBaker104 said:
Looks almost definitely a snap back as the case is plated and the back appears to be stainless. The case looks pretty filthy so you may struggle to find the cutout to insert a case knife. If you carefully roll a scalpel blade round the join and look hard with a loupe you will probably find it
It's gunk from a reaction of the leather strap and the brass? Strap bars.
23 minutes ago, StuartBaker104 said:
I'm going for Landeron 48, although it could be a 54. Can you see a calibre number stamped under the balance wheel?
Looks in a good state. Have you managed to give it a wind yet?
I can't see the number under the balance wheel, I've looked on ranfft archives and it isn't quite the same as the 48, 54 or 248. Did they differ slightly in the same movement at all?
It's not a 47. Very different chrono bridge.
Key difference between 48 and 54 is size, but they share many parts.  148 and 248 are later variants of 48.
If you are planning to tackle it yourself, you will need this... http://shop.joseph-watches.com/joseph/members/FMPro?-db=joseph_archive.fp5&-lay=web&-format=esemblo_details.html&kategorie=esemblograf&-recid=12607829&-token=002&-find
Thank you, I wish I was more clued up on part names and then I could have explained. They only made the 47 in 1937 didn't they? It must just share some of the same parts.
I have now taken the balance out Stuart and there is no calibre number anywhere.
    • Thanks everyone for the replies. It seems setting the hand is a bit of a guessing game, and I thought there would be a very specific way to do it. Since the reserve indicator hand moves clockwise as the spring is wound, I tried setting it right at the start of the black side. But setting it there doesn't really make sense, because by the time the spring is halfway wound, the hand is only at the end of the red side... In my head halfway wound shouldn't mean the hand is still "in the red."
    • Lovely part of the country! I spend most of my days driving along the A64 for work in and around York. I'll be sure to drop plenty of questions soon! I've actually got a couple of watches on the way that I'm pretty sure I'll need some help with! They look pretty beat up from the pics but I love a challenge and an excuse to buy more tools 🤣
    • I have two of these in my home. You need to remove the movement from the case, take off the hands and remove the dial and take a few good photos of the front plate so I can see what the problem is. The round nut unscrews and the hands pull off pull them off from the center and not the tips as you could break them.
    • I asked the question of one of the sellers. Its for removing the pins and making the holes in motorbike drive belts. God knows why they were both in two seperate joblots of watchmaking tool, thats bizarre. I haven't posted your setting lever steel yet mike, been busy with my mum past few days and had a locked myself in at home lazy watch repair day today 🙂 but I'm out tomorrow so i will get it off to you then.
    • Hi everyone, I tried looking for answers on this online but came up with nothing, so I'm hoping some of you knowledgeable people might be able to help. I have an Elliot clock that has been in my family for at least 4 generations. I recently enherited it, and I'm trying to get it to run properly again, as it's been neglected a bit.  Here,s the problem. These clocks have a silencer mechanism, which is supposed to stop it from chiming between 11PM and 7AM but for some reason mine is silent between 1AM and 9AM. I have tried figuring out how to adjust it but have not managed. Does anyone have any idea on how to correct this? Please find attached some pictures of the clock. Thank you!
