When you push in a friction jewel, does it snap into place. Is the hole in the metal plate on the watch concave on the inside? The reason I am asking is that I did hear a click when I pushed in the jewel in the picture below.323c9c90e121556fa81c84952477739e.jpg55cbcff24d4789a9e2d7b80084564970.pngc0f609c7f89189f7ae075ee2c660fa6e.png
It might be worth having a close look at the jewel with a loupe to make sure that it has cracked or fractured. Unless the Chinese have completely thrown convention out of the window the hole into which the jewel is pressed should be parallel sided so as to allow the adjustment of end shake. The click you heard may just have been the jewel cracking if the hole wasn't quite big enough.
I had a look and it seems ok. I thought the walls were parallel! How do you measure the jewel diameter and then the hole diameter to ensure the hole is the right size for pushing in the jewel? I do have a micrometer for measuring the jewel but not sure how to size the hole and know if I need to ream it.
    • I suppose? If it worked before and it doesn't work now I guess the question would be why does it not work now? That would come back to if you did not have the chronograph module on will it work or is the chronograph module sucking too much power out of the watch basically 99 usually when they go bad you can hold on the tube part and usually just spin the wheel because it has zero holding at all so usually when they go bad they go bad very bad. You should build hotel when you set the watch as to whether it seems to have any friction or not. I'm just wondering if the chronograph module is the problem.
