hi i need help with the above(sp16) does anyone know where the pieces of the oscillating mechanism fit.i am a novice but have managed to re-assemble everything-via photos!-but could not with these pieces because everything came apart! would appreciate any help.
Ok so let's see if I can explain this and it make sence. The wheel with the very small teeth goes between the crown wheel and the ratchet wheel where there is a spare jewel hole. The pawl the thing with the two wheel driving prongs on goes in the centre off your bridge underneath it on a little peg with the longer of the two prongs to your left as you lòok at it. It is then placed on your train wheel bridge with the two prongs of the pawl either side of the wheel with very small teeth make sure pivots are aligned and screw down. Screw down rotor and hopefully your autowinding. Hope that made sence.
Mick
Looks like a Seiko set up? If you can learn a little how a Seiko 6309 work i think you can put this together also? Check seiko 6306/6309 on youtube?
thanks for your help but although based on the seiko, parts are slightly different and the pawl wont stick to the bridge so is difficult to line bridge up over the pawl.think there could be something missing!
The small part is nothing to do with the rotor mech it looks like a roller table jewel and half a staff. Your last picture is the one i was interested in the pawl jewel fits over that little post now remove the bearing housing 3 screws so you can see the pawl underneath when you've screwed the bridge down after putting the pawl and other wheel in place place the bearing housing back on top rotating it until the post engages with the pawl jewel hole then rotate until the 3 screw holes ate aligned and bobs your uncle.
    • I suppose? If it worked before and it doesn't work now I guess the question would be why does it not work now? That would come back to if you did not have the chronograph module on will it work or is the chronograph module sucking too much power out of the watch basically 99 usually when they go bad you can hold on the tube part and usually just spin the wheel because it has zero holding at all so usually when they go bad they go bad very bad. You should build hotel when you set the watch as to whether it seems to have any friction or not. I'm just wondering if the chronograph module is the problem.
