Hello all,
A friend sent me an old Ingersoll Triumph wristwatch to repair. I think I found the problem pretty quickly but someone had tried to lubricate it with WD40 so I decided to strip it and service it.
No problems until it came to the mainspring barrel. I don't have much experience of these types of movements and I can't say I have come across this type of arrangement before. Simply put, I can't remove the barrel at all. The screw keeps turning, with it the barrel and the ratchet wheel. I cannot work out what to do and would be humbly very grateful for any advice.
I have attached some photos to illustrate the thing.
Thanks in advance
6 minutes ago, vinn3 said:
you can service the main spring and leave the barrel attached to the plate. it looks like the cover will lift off.  vinn
If the ratchet screw and wheel are not removed, the barrel arbor cannot be lubricated to the plate. Not a good idea.
Hold the barrel just like one would do with a nut and bolt.
Thanks for your replies but I have been struggling to do that. I am scared of damaging the barrel if I hold it too tight. The screw won't budge.
alert !  that screw is usually LEFT HAND THREAD  most often broken,  even by good  mechanics.   THAT,S  why i suggested leave it  and service the main spring and lube under the screw.      if you break the screw - you are screwed,  cheers vinn
Nick;  on a watch,  it is hard to determine "if it's left handed"  unless you are told or find it in print.  it takes so little tourque to brake it.  if you are lucky,  only half the head brakes off and then it can be turned with plyers ( the other direction).  vinn
It's not hard. The threading is so the screw doesn't get lose with the rotation of the wheel below it. For a ratchet wheel, observe the direction when winding.
Edited by jdm
Dear all. Thanks so much. It was a left hander. I hadn't come across two left hand threads on a watch before. Another lesson learned on the long road that is horology. Thanks again
Nick
Very good. Please remember to mark the best and earliest correct answer.
Hi JDM. How do I mark the answers?
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
