CONFESSION TIME
TimFitz
I bought a nice new roller table remover to aid in replacing roller jewels.I have some old Ballance wheels with tables attached to try my tool  on. Then I watched a great video by our founder, where he used this tool to remove the table.I was very impressed & confident.
I took the shiny new tool , carefully slid it between the balance wheel & roller table, checked (under magnification) , put the whole thing in a plastic bag (so not to lose ping the table across the room) , then gently squeezed. Nothing happened, so I squeezed a bit harder, still nothing. So instead of using  my brain & watching the video again to see if I had it correct. I gave a mighty roar & squeezed like "Mean Mountain Dean". It popped right off the staff. I patted my self on the back saying "Your The Man".
It's then I noticed the balance staff was cut in " twain " as they say across the pond. What could I possibly done wrong? Perhaps it was a faulty old staff ? So you have two more old Ballance wheels in the box, try again? Ping there goes another one. It doesn't take Alan Einstein "sic" to figure out it must be me, not the tools or staff.
After re-watching the video It dawned on me, I had the tool upside down " (duh) "
There I confessed & feel much better. You can bet, I won't make that mistake again !
Edited by TimFitz
error
so where is Marks vid using this tool and which way up do you use it then ?
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
