The ETA 1100 movement came to my notice a few months ago because it kept cropping up in articles on such brands as Technos, Atlantic and Breitling - all brands which used the movement (along with others, of course) in manufactures in the 1950s. Atlantic might be less well known in the UK because their main market was Poland, but there are some lovely Atlantic watches out there worth looking at. In the classic style, of course, which is what appeals to me.
I took a punt on a Swedish watch brand, called "City", which also used the ETA 1100. It looks rather nice, it was rather cheap, and I'm looking forward to seeing it close up next week.
Nice classic design... the back bone of the Swiss watch industry. The fact that a lot of them are still working half a century later is amazing..!
Anil
Thats nice Will. It reminded me of one of my (many) unfinished projects, a Garrard with an ETA 1120 movement which I had managed to fit into a NOS case from another manufacturer.
Although I was quite pleased! The caseback was for an automatic and sported the other makers name, inside and out so after looking at yours and having a fit of inspiration I turned to my recently acquired mini lathe and a mineral glass and heres the result!
Now I need to make a new movement ring and give it a service and I may try to blue the screws...... could get messy!! :)
    • I suppose? If it worked before and it doesn't work now I guess the question would be why does it not work now? That would come back to if you did not have the chronograph module on will it work or is the chronograph module sucking too much power out of the watch basically 99 usually when they go bad you can hold on the tube part and usually just spin the wheel because it has zero holding at all so usually when they go bad they go bad very bad. You should build hotel when you set the watch as to whether it seems to have any friction or not. I'm just wondering if the chronograph module is the problem.
