U.S. Shipping Board
TimFitz
Just completed a cleaning of a watchcase & a Waltham 15j Pocket watch movement.
Then I put them together to make a whole watch. Neither came to me as a whole timepiece. I have been looking for an unusual case to put the movement in & I found it at Dave's
watch parts.
The movement was very dirty and very sluggish & the case was very tarnished with dings and scratches. The crystal was not bad with a lot of small scratches (fixed with cerium oxide)
So here are the before & after shots
It is interesting... Walthams were manufacturers of movement's. To my knowledge they never sold watches.
They would retail to Jewellers etc. It was normal practice for a customer to pick a case and select a movement. Then the Jewellery shop would fit movement to case. So really the "watch,being the movement " was never supplied in an original case, as is the practice today.
That's why you could have a Waltham in a case inscribed say 1920 but the movement could be 1916 but it is the case it was first fitted into.
All you've done is something similar to original practice of 100 years ago.
The point I'm making is Walthams never supplied cased movements so are any Walthams truly original by definition.
1 hour ago, TimFitz said:
I realize some people are down on re-casing, however there are tons of movements & not as many cases. I think re-casing for a personal collection & not for resale is the right thing to do. Now I have a beautiful watch to use and admire.
I'm going to put black lacquer in the engraving, to make it show
I can't see any reason if you were to sell, it wouldn't reach a high price with the work you've done. It's obviously a re-cased movement because you've fitted a hunter movement into an open face case.
I own many Walthams and due to the nature of the trade as previously mentioned, there's no way I could be certain they are in there original cases.
Most modern manufacturers use trade movements but they leave the factory cased. So originality is easier to identify.
    • Nice file  Just got old pocket watch in and tools,  can I get it back together or should I give up.  we'll see  thanks for the info
    • @HectorLooi Yes, I would say that Mumbai has the highest liquidity in terms used watches. How was your experience with these used watches and what watch brands did you buy used? I have always found the vintage luxury watch segment in India a bit shady. Quite a few are genuine watches with genuine matching parts but just not from the same one.
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
    • @steve1811uk close but no cigar 🙂 I don't smoke anyway. I checked in my stock of parts and that's the closest I got to your dimensions. Good luck in your search. @RichardHarris123 I have an accumulation of all sorts of odds and ends that I acquired as a result of buying up the tail ends of old watchmakers estates. Usually after all of the great stuff has been stripped out, which means that the sweepings off of the workshop floor can be had for peanuts, but if you have the patience, can often be found to contain gold (both literally and figuratively 🙂 ). These came to me through on of those purchases. I doubt that I will personally be able to make use of even 10% of my accumulated stock, but having it, and knowing what I have, means that I can at least pass bits on to those who can use it whenever possible.
    • Hi and thank-you for your suggestions, as per Mark's instructions I checked my browser "Safari" and spell check and grammar was not ticked. So all sorted. Thanks CJ
