Any one know of the UNITAS 34 ?
Did the old battery leak and damaged the circuit board? Can you post some photos of where the buttons make contact on the circuit board. Try cleaning the gold fingers on the board with alcohol and also the conductive rubber strips behind the LCD display panel. -
How do you safely remove the stem after fitting hands? I’m talking about the push type setting lever you need to push to release the stem. Some dials can be intricate, glossy finish, lume dots etc. and placing it in the movement holder can be quite risky and cause damage.
By rjenkinsgb · Posted
Off topic, but that just brought back an old memory! My mother once told me about a minor incident as a child (born 1917, so 1920s, at a guess). She used to use "Fish glue" for a hobby - an apparently smelly glue that had to be heated to be usable - and to heat it gently, she had to stand the tin in the kettle. One day someone filled the kettle without seeing the glue tin.. The tea tasted of fish for some time afterwards! -
As Richard said, this is a really old school trick for joinery. Cut i strip of paper, might need to be watch paper around 1 " x 1/2" lay it over a staking block then press the stud screw into and through the edge of the paper upto the head of the screw. You probably wont even need to pull the paper away the head will pull itself through. -
Thanks Jon, my mum is getting there day by day, so strong and determined, they dont make em like this anymore 🙂 Old folk are so amazing, my mum used to love her golf, she didn't stop playing until she was 70 . Enjoy your trip and your golf.
