Brass
I have a really nice Hamilton 978 Pocket watch that I have just completed. I needed a new crystal & dial redone,and serviced the movement. The watch has a beautiful solid brass case that was very badly tarnished. I got the case all cleaned and polished to a beautiful shine with a lot of work. What is the best product if any to seal it from tarnishing again. I know they used varnish originally. Here are some before and after photos. Does anyone have suggestions .
Thanks
Not sure if any of you have seen any of the Clickspring videos on Utube where he builds a clock from scratch but he dips the parts in the lacquer.  Would be one way to avoid brush strokes and insure 100% coverage.  Been awhile but I believe he thinned the lacquer first.  Great looking watch TimFitz.
Thanks I'll look for it
1 hour ago, TimFitz said:
  We can't purchase  horolacq here in the USA's to dangerous, I might hurt my self or others by spraying them  , I can however buy up to four guns a month..Sometimes I cant believe the stupid laws in this country.
3 minutes ago, lluvitar said:
Looks like the lacquer is thinned 50/50 before dipping.  Here's a recent video starting just before he dips it.  These videos are every bit as addicting as Mark's and make me wish I had a lathe to play with.
Dipping pendulum in lacquer
I can't take on any more interests, there are only so many hours in a day and patience in my wife.
Well whether it's fortunate or unfortunate for me, I'm retired and my wife has the patience of Job.  I'll never get a lathe though, but would love to spend an afternoon or two turning some brass.  And the level of blueing he achieves on the steel is phenomenal.
When you polished your case was it by hand or a buffing wheel.
I am a full time Artist , part time computer repair geek, private Pilot, watch collector. To be honest my wife is a saint.
I got the case all cleaned up with my Dremel and good old Norwegian steam.
    • Looks lint the teeth on the hour wheel aren't meshing with the teeth on the calendar intermediate wheel, maybe the hour wheel is sitting on top of this instead of meshing?
