Cannon Pinion lubrication ?
What is the movement??? Most friction fit cannon pinions do require lubrication. You typically apply some oil to the center wheel post - not the inside of the cannon pinion. For most watches I usually use some Moebius D-5
Movements in general.
I've got service guides for some ETA and Seiko movements which show lubrication to the centre wheel post. I wasn't sure where to lubricate.
