You might be a pocket watch addict...
If you pick out just the right pocket watch to wear to a special occasion.
If you find the ticking of a watch soothing instead of annoying.
If you have ever been asked why you need so many pocket watches.
If you've ever had someone comment on how ridiculously heavy your watch is.  (sometimes followed up with "how can you wear that thing?")
If you love it when someone asks you what time it is, because you get to show off your pocket watch.
If you own some pocket watches because they have special meaning to you, but also own some just because they're pocket watches.
If you've ever wished a pocket watch could talk and tell you its history.
If the bigger and heaver, the better.
If you sometimes get up in the morning, and have trouble deciding which pocket watch to wear.
If you feel sorry for people when you see them checking the time on a digital wristwatch.
If you have ever retrieved your pocket watch from your pocket to check the time, when you don't even care what time it is.
If you have ever looked at the speedometer in your car, and thought that it would look a lot nicer with a mint condition, Montgomery dial.
If holding a pocket watch in your hand makes you feel a little better, no matter how bad of a day you've had.
Edited by Keitharoo
Yeah, makes me sad. Unless it's a vintage Seiko :)
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
