Tips for bending a second hand back
Have a Seiko 9139 that wont really make it to the middle. There i a half second wrong. It bugs me Have tried to bend it but it gets back in the same position again. If i can hold it still i would work i guess? But how should i hold the tail and the pivot area still som i can bend the long second a little. Under control.
The proper way to fix this is:
1. Remove the second hand
2. Run the chronograph.
3. Stop the chrono
4. Press the chrono reset - this will zero the mechanism by striking the hammer against the chrono wheel heart piece
5. Support the chrono wheel pivot on an appropriate tool - either a special holder for the movement or something like a bergeon 5409
6. While firmly depressing the reset lever, install the second hand exactly at 12:00 and press firmly in place
Holding the reset lever will keep the chrono wheel locked at 12:00 enabling you to get the alignment perfect. It is critical to support the pivot/jewel else you are likely to dislodge the jewel.
3. Stop the chrono
Have a holder for supporting the jewel so that is not any problem. The second has a fixed point where it sits at the pivot. I just wanted to bend the second a little to the left making it more straight.
58 minutes ago, sstakoff said:
I have also used a seitz jeweling anvil with appropriate pusher as a platform to support the jewel/pivot
Have a tool for the job of supporting the jewels . Have to remove the oscillating weight but that is no big deal.
I will keep it as is at least for now?
Have you checked to see whether or not you can rotate the heart piece on the pivot? Unless the second hand is actually bent incorrectly I wouldn't want to bend it. Doesn't seem like the correct repair.
On Seiko 6139 you can't rotate anything. But i will figure something out? Have some ideas i will test.  Like having two supports and laying the hand on the side and pressing a little in the middle?
Get two very small diameter nails and hammer them very closely together into a block of wood leaving about three millimetres sticking out.  Place the second hand face down between them.  Now starting at the tip end of the hand between the nails, gently push or pull the hand to ease out the bends slowly working your way to the centre tube.
    • I disassembled the hands of my Citizen Pilot Super Titanium Radio Controlled AS2031-57E a couple of times.  The second time because on the first attempt i evidently did not push the hour hand well and in practice it was not well fixed and moved receiving even small bumps. After the second attempt everything seems to be ok.  Except that i have the impression that giving a little more sustained blows on the wrist, the hour hand still has a slight movement, in the order of half a second or less. It is a normal, topical and usual thing about this movement, which, i remind you, is exclusively electronically managed, each hand independently, a clearance in the movement that it has of its nature, or it may depend on the hand is not yet well attached to the pin and should perhaps be replaced because the hole has slightly enlarged?
    • This is something a lot of beginners and amateurs struggle with Nev, being able to remove the staff without distorting the hole of a non steel balance wheel. Having the right tools to do this safely  and effectively is not easy. Even with something useful it takes a lot of practice, i spent two days not so long ago practicing cutting away the balance wheel hub of a staff using a 25mm diamond wheel.  I didnt manage to do it once without catching the underside of the wheel.
    • Then you should have something that prevents the case from moving. I just bought one of these Seiko S-210 but haven't received it yet.
    • This is english watch, I guess from Lankashire Watch Company. I am not sure if suppliers have staffs for it. Yes, making a staff is the normal solution here. You are happy with the tools, but look how the riveted staff has passed thru the balance arm hole. Do You think that the hole has correct diameter after that? I mean, if original staff is used, will You be now able to rivet it easy and keep the balance centered correctly?
    • Interesting, but not very accurate, unfortunately. Using the word "Radiation" without specifying the specific type of radiation [what is being radiated] is one of the commonest mistakes - and most confusing to non-technical people.  Also, I believe the commonest lume in general use nowadays is just a phosphor compound that is "charged" be exposure to light? I've never personally see a watch with tritium lume, and it's not something I would particularly want as the decay is quite rapid with a half life around 12.5 years. Tritium is also of course radioactive, emitting beta particles, and it can possibly cause cancer if ingested!   Re. geiger counters, it's also important to note that many on internet sites are fakes that detect RF rather than, or as well as, ionising radiation. Or just low quality that likely only detect gamma, or gamma and alpha. Only high quality mica window GM tubes will detect beta; all the cheap geiger counters I can see on on ebay at present that show the tubes, use glass or quartz - despite claiming to detect beta
