Evening folks
i am starting another watch build project, (love keeping myself occupied ), and this time the movement is going to be a 2836 as I have picked up a couple cheaply (a good time to start a complete strip down in my opinion)
i have been watching Marks 2824 strip down video and have 2 questions.
1/. is the 2836 movement similar as it appears to the 2824?
2/. Do the 2836-1 and 2836-2 share many common parts (happy to be enlightened on this subject as there appears to be a 4 Jewel difference as I can tell
as ever, thank you for any replies
ETA 2836-1/2 is the day-date version of the 2824-1/2 . So in it's the same movement and share many parts from the 2824 movement . Where the extra jewels are i don't now? Maybe the reverse wheels?
Thanks Rogart, that confirms what I was thinking, (it takes time to learn something new, but knowledge grows every day)
most appreciated
Dial side has some different parts to accommodate the day wheel.  The calendar gear, and its spring set up is completely different to that of the 2824-2.
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
