Stem for 6309
Hello all
I am in need of a stem for a Seiko 6309. The part number is 354601. The Seiko 5 I am restoring had a big dent in the crown but is a one piece. I have a NOS crown, but it's a screw on. I have called all the suppliers I know in the US and checked eBay. EBay has one for $15 plus ship!
Any other suggestions?
i believe a 6319 will work also. it is a derivative of the 6309. as is a 6306 and 6308 - if you can find them.
i'm not sure of what you mean by a screw on crown. they all are.
i have two of them, but they are a bit short to use. they might need a stem extension. it's yours for postage.
Edited by ramrod
i'm confused. it sounds like the OP has a two piece, screw down diver's crown and stem, but he needs one to fit a seiko 5 that he's restoring. the diver won't work.
clear it up, please, OP
Let me clarify. This is not a 6309 diver. It is a vintage Seiko 5 7309-8900. It has a 1 piece non screw down crown that has an o-ring on the stem section. I have a replacement crown which accepts a tapped stem. This new crown has a Seiko part number. The part number above is a Seiko part number for the stem only sans crown. Not a 1-piece stem and crown combo.
    • RichardHarris123: Hello and welcome from Leeds, England.  I have family all over Australia, went as £10 poms Thanks Richard. Hope you’re able to visit your family here and that they’ve all done well 🙂 My relatives arrived from England in the 1790s transported on the ‘Second & Third Fleets’—a story of timber sailing ships, of convicts and doing well in this huge Country of Australia. When I visited the UK in the 1980s, I was too young to comprehend the depth and breadth of its history…  Best wishes, Mike William Chapman, my 4th great Grandad’s charges, at age 23 read at the Old Bailey; sentenced to 7 years of transportation to Sydney.
    • The whole process and the progress are closely observed, it's hand-driven and very controlled. I can't see the "danger", unless you are watching the TV while doing it. As you could have read, and in this quote "wheel" is the balance-wheel.
