First Dial From Scratch!
Most of the dials I use are either made specific to a certain movement, or are modified to fit other movements. But this time I needed a dial that would fit a specific size case(12s case) and would also fit the movement (10s) that I wanted to install in that case.
I thought it might be better to try and make one from scratch....
I milled it out of 18 gauge Brass Sheet. I wanted the look of a triple sunken dial and milled it on my lathe to mimic that look. Since it is a pretty thick dial, I had turn a seat at outer edge of the dial to allow the movement to sit at the right depth so that the stem would line up with the tube on the case.
I'm very happy with how it turned out(pun intended) as it was my first ever attempt at doing this!
I'll update with a picture of the finished dial when I get it back from the refinishers...
Will you solder on dial feet - or do you have another fixing method in mind? If feet, what will your method be for making them?
Looks good so far!
I soldered the dial feet using my Dial Feet solder machine, basically a welder. You'll notice the file marks from removing excess solder so that the dial seats flush with the movement.
Nice looking job Don, I really appreciate quality engineering!
Have you worked out a style for the graphics?
I'm thinking a nice matt silver with either style of numbers in the following pictures...
This one I had done with a Howard movement...I posted it here in a previous post.
I like the font in this dial. It looks a little more elegant!
Finally got my custom made dial back from the "Dial Refinishers"...
They do pretty good work, but I'm kind of a perfectionist so I really notice the little flaws in their printing process...couple of wayward specs of dust caught in the finish coat and the 3 has a glob of paint in it.
All in All, it looks pretty nice, I do believe!
Not the dial, but a good shot of the Hamilton 921 movement...
Thanks Geo! I do have to say that I'm pretty proud of this watch! Everything on this piece just kind of came together perfectly! And, I was very satisfied with this strap too! It compliments the dial color very well and it looks a heck of a lot more expensive than the $15 I paid for it...
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
    • Hello and welcome to the forum Dan. Used to know Middlesboro quite well, that was twenty years plus ago. Attached a little reading to get you started. TZIllustratedGlossary.pdf
