Fixing Hands
Hello,
I got this watch in an essay contest many years ago, and it got put the the washer and dryer a few years back. Im wanting to try to get it running again. As far as I can tell the second hand has just came off (broken off?). It's not running either, so I hope its just in need of a battery. Any guidance, advice, tips or direction would be greatly appreciated.
Please and Thank you
The first thing you need to do is open it up and look inside at the movement to see what damage has been done. It looks like a flip off back so that shouldn't be a problem.  Post a photo and we can guide you on what action to take. In some cases a complete replaceable movement could be the least expensive option.
Look very carefully with loupe or magnifying glass to find out cal or movement number, looks like a miyota, PCxx?? (used in most inexpensive quartz), once you have determined movement number, just search on web, lots of new movements relatively cheap from supply houses, (gaskets too) there's a small button or detent to remove stem/crown, press with sharp pointy object and pull out stem, once stem is removed, entire guts can be removed, now it's about taking off hands and dial, warning: some of these dials are glued on during assembly process, can be like surgical procedure to get them off without damage!! I have done more than a few of these and it's nice to have something that you have fixed for remembrance.
If it's been through the wash, chances are movement is 'toast', but who knows, try a batt, you'll need it for the new movement anyway. Update us with your efforts and if you need any more help, good luck!
Thank you for your input! Originally I had started this post to get the hands put back on, I got that and got a new battery and it was good, then it started either losing time or stopping/starting, so now I figured I would just attempt a replacement.
So, as far as the part number goes, I can read this: No Jewels Unadjusted/Japan/S110/PC21A
I found a few matches for that on Esslingen.com, but it looks like there are a few different ones by the same #, any advice?
It's a Hattori, readily available and inexpensive. As long as it measures the same as old one (Height and Width) and dial legs/feet match up it should not be a problem. Esslinger is a good source. Cas-Ker Co also stocks. Remember there may be some adhesive under the dial, so be gentle when attempting removal.
HATTORI PC21, 17.8mm x 15.3mm, Height - 3.15mm, Battery 377
DIAL FEET  5:00/11:00/7:00/11:00
Your gasket looks okay from pic, (to me)
Good deal! Found the movement, and I I'm going to get an assortment of gaskets ( it looks ok in the pic but it was actually in half a dozen pieces).
and there was some glue but not bad, I got it off without breaking anything. That being said, I do wish I had just found a pro to take care of this. If hate to mess it up now.
Let you know when I get it finished. Thanks again
on Esslinger's site, this movement calls for:
  • Requires watch hands: hour 1.20, minute .70, and sweep second .17 mm
Is that a typo, because those ratios don't look anything like what I'm finding in their watch hand kits...
I got my order today: movement, hands, crystal, gasket, hand inserting tool etc.
Once I got it assembled I couldn't get the stem to wind to set the time. The stem turns, but the hands remain stationary.
At one point the second hand ticked, then it starting just jumping back and forth in one place.
What would cause that?
Is the stem engaged fully, (pulled all the way out?) I like to put batt in and replace second hand before recasing, just to confirm operation. Is it possible dial is making contact with hour/minute wheels? Preventing them from turning.
It's tricky to get hands aligned properly and set on wheel(s) so they turn properly and don't catch each other. I think Marc has video on this site for hand installation,  granted it's for a different watch, but theory is still the same. Guessing.... but second hand may not be tight enough? or too tight?
OK it's officially finished! I took it to a watch repair shop in the mall. Apparently it was a combination of improperly inserting the hands and the hands being butchered to heck. 20 minutes and $20 later, good as new. Ironically the hands were the original problem, and the only thing I had to take in and pay to have done. I did get some simichrome and polished it up and put in a new crystal.
I definitely have a greater appreciation for the craft now, thanks a ton for all the advice and info!
Good for you! It never hurts to have a 'pro' look at something that has you stymied as long as they don't want to charge you up the wazoo for the privilege. Often valuable info can be gleaned from inquiry. Many time jewelry stores, who send most everything out to watchmaker, will quote exorbitant prices for quartz swaps, look at how much your total cost to redo this watch and weight that against your willing to spend to have someone else do the work. For the $20 you spent to have hands set, (not including movmt, glass, gasket, etc) its probably worth it. I hope this experience will encourage you to take on future projects.
    • That's the right technique Mal 👍 If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean. Something like this, but tbh its better to just learn to do with your fingers.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
    • Hope you mum keeps on mending. I was adamant that I was going to get myself going after my stroke. I was only 52. I still have a lot of life left to live. Some people give up. Some people don't let it beat them. Your mum sounds like one of the winners. 👍
