Watch tools identification challenge.
BeyondWorld
1) Well this is a the watch opener tool, pretty much the reason why I bought them.
Not sure what make it is though, no markings, and I think some bits are missing.
The pins I think some from other sets will fit in fine.
But the bases I'll probably have to make.
Picture 2 Is the interchangeable rings that goes with tool from picture 3
Picture 3 Ring sizing stretching tool for rings without stones, such as wedding rings. The idea is to find the right width to fit the ring by changing the one on the right, the ring to be made bigger is put over the left side and in line with the right side, screw the thing close to the ring to be stretched then move the tool by tightening it and keep moving it back and forth. What will happen is the gold will stretch and increase in size.
Picture 4 I think is for making watch lugs curved.
Picture 5 is a vice for holding and filing down watch bracelets to fit the width of the watch.
Picture 7 Is a watch bracelet cutter, you put the end of the bracelet into the slot and squeeze and it will cut the end off then file and shape to fit the width of the watch.
Picture 9 I think is a burnisher used for placing gold leaf. It should be nice and shiny not rusty.
What I have described here I have used many times in the past in my workshop apart from tool 4
Edited by oldhippy
    • My overall preference is to use traditional names and terms, that became my habit when i was taught joinery by old boy chippies 2 generations older than me , that had their time in the 40's. But what i often do is adjust the names and terms i use according to who I'm talking with. Sometimes i will say trainside and occasionally watchmaker's side. I try to find a balance between accommodating other folk ( there's no point speaking a foreign language to someone who doesn't understand it ) and using a name that appears to me to be more relevant as to its use or description. But using the name lever can be quite confusing,  some watches might have parts that are also levers, release levers, which in effect is what the pallet fork is, an escapement release lever.
    • Then put the case number in here https://www.cousinsuk.com/category/filter/search-seiko-case-parts and it should give you the crown
    • I come across to replace the crystal of a 7734 chronograph.  What make it special there a printed chapter ring  which fits inside the recess of crystal before inserting into the case. I am thinking of a high dome crystal such as Sternkreuz ATCH, fitting diameter OD332/ID320.  For this purpose, tension ring will be removed and fit in the chapter ring.  I understand the crystal size may not perfectly fit these two dimension.  Should aim to find the right ID, then OD can be grinded to reduce without much difficulty.  To find the right crystal, the easiest way is to get know of the OD/ID relationship of Sternkreuz ATCH/ATCG (otherwise the OD of the crystal and tension ring).  I hope you are able to help to minimize the trial and errors.
    • The case number should be on the back.
    • I agree, I call it a pallet fork for two reasons, it was the name used when I started watch repair both in written documents and on videos and calling it a lever causes confusion as seen.  Plenty of other examples where there's more than one name. What do you call the opposite side of the movement from the dial side?  I've heard you call it the watch makers side.
