Hi, everyone!
I was looking at a picture of an EB1297 watch movement and in the read up it says that the watch has "an engraved adjustment minutery on the dial side."
I can't even guess what this means, but do you know?
Thanks.
Len.
Dial side of a FHF150 showing  15 minutes worth of engraved adjustment minutery.
Completed watch movements would come off the production line and be fitted with a test minute hand. The movement would then be regulated by observing the transit of the minute hand over the engraved timing marks through a microscope and timing against a know source. The test hand would then be removed, and the movements put into stock ready to be matched up to any of the various combinations of dial, hand sets, and cases that were in the makers catalogue, or shipped out as bare movements to another maker.
Well, I'm blowed!
Thanks for that information, Mark, I find it totally amazing.
Slowly, but surely, I'm gathering more knowledge about 'what makes a watch tick.'
Again.................."thanks."
Len.
    • First of all, thank you for the pdf file of the book on how to replace a gem. So, if there is a problem with the ruby in the movement, should I buy a new or used movement and replace it? When I watch videos on YouTube of people fixing used watches, I feel like there should be a way to buy a gem. Is there no way to buy it?
    • I suppose @donutdan is not forced to earn his living by repairing watches.  I suppose he does it as a hobby and wants to gain experience, to get better in watchmaking and time is not the issue. Then @donutdan should rather try to repair the damage instead of swap parts from a maybe intact other movement. Swapping parts is not watchmaking. And often swapped parts are not the expected solution of all problems. All mentioned damages are repairable. Frank
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
    • I am puzzled by something a snipped out something from your image and what exactly disassemble tell us? my confusion is the symbol for FHF looks like image I have below year symbol as a star and righted this instant are not finding what that means? I suppose we could use the fingerprint system to verify it really is what it claimed to be. Size itself is really interesting there's almost no watches in that particular size. Then were missing details in the photograph above like diameter of movements to verify it really is the size and are missing the setting components.   went to the bestfit book looking at the symbols didn't see it. Look at the link below I did find it back to the bestfit book and yes it really is there https://reference.grail-watch.com/documents/history-of-ebauches-sa/ then bestfit book says lists the size as 10 1/2. one of the problems with vintage watches is finding parts yes a donor watch would be good.
    • Actually, this could be the issue. Drag from the module could be overcoming the cannon pinion. It was definitely not at the point that the driving wheel was loose on the cannon pinion, it took a little bit of effort to rotate it when applying the grease. Maybe I need to look again at applying oil to the pivots.    Yeah, it's very annoying. I don't want to give up on it, so back on with it over again until I catch a break.
