Finding a watch-housing / case?
Hello All;
About a month ago I bought a lot of 4 movements, for spares or repair, on eBay. Three of the 4 movements were AS-984, two with 15 jewels, one with 7 jewels. Two of them had broken balance staffs. The one with a good balance was a semi-runner and even after a service, it stopped in certain positions. Long story short, I threw all the parts on a pile, sorted the best which fitted the 15 jewels movement, and build a movement which runs very, very well. It's within 2-3 seconds a day. In fact it runs so well that I like to find a case for it.
My problem is finding one, as on eBay, and other watch-parts sides, you'll find lots of loose movements, but for some (to me) odd reason, hardly any cases can be found.....are they all thrown away, all to different in size to be kept or am I looking in the wrong spots?? How does one go about finding a case?
As said, the movement is AS-984 and the dial diameter is, like the size of the movement itself; 23.7mm. Probably a men size at that time, now considered more a ladies watch.......fine with me.....
Can anybody give me some advice how to find a suitable case........
Thanks on beforehand ;)
Edited by Endeavor
8 minutes ago, Endeavor said:
Usually they provide pictures from the movement which You can identify (for example @ www.ranfft.de) and considering the bidding if the parameters match. Its really hard to find "just the case" :/
Or check here:
http://www.speedtimerkollektion.com/shop/index.php?cPath=32_85
once i bought a movement for parts fore really cheap.
Edited by szbalogh
Hi endeavor,
As Roger just said, the stem height is very important. You can always make do with spacers for the rest. I think you can sometimes manipulate that height with a shim if too short and even with a thicker dial...but it is all limited to how much room is left for the hands on top. In my mind, I would check according to the specs below. Remember the height given is just the height of the movement not the stem height. The size is for a medium size movement so to speak: either men or women. It is helpful to know this height in order to calculate the clearance from the top to the crystal (based on the cavity where the movement fits) -- just add the pinion height for a total height -- since you don't want to have the watch hands rubbing against the crystal. Hopefully ebay may have several options...check these specs against the original movement specs of the case you decide to get.
PS. I don't do this much -- or almost never for "uncommon" movements vs. available common cases (virgin) -- so just my opinion.
View picture in original size
Fig. 1
Fig. 2
AS 984
Features
manual wind
sub second
Data
10.5''', Dm= 23.3mm
H= 3.8mm
F= 0.5mm
T= 1.8mm
15/17 jewels
f = 18000 A/h
power reserve 40h
Balance staff U841 / U3093
for balance with/without screws
Stem W1131
Mainspring / battery
Zf1389, 1.70 x 9.0 x 0.10 x 290mm
Hands
1.30 x 0.80 / 0.20mm
2 minutes ago, Endeavor said:
Lots of good info already to consume and........ digest......... :thumbsu:
I love drawers.... Roger ;)
Found one that could work? Pretty small with 16 mm lugs and 24,3 inside. Brass with chrome. PM ? Not sure what you look for? I will just find the case back.
@rogart63 I did send you a PM ;)
@szbalogh Interesting "speedtimerkollection" link to watch cases ! So here is where they all end up !? Opens new possibilities if one has a nice movement, but no case ! Thanks !
@bobm12 Thanks for the info ;) I found similar info already, but for a case I didn't realize the distance from stem to dial ........ obviously, once pointed out........it makes a lot of sense :)
No idea yet how to order these spacer-rings and which dimensions are required, to look out for. I think CousinsUK have a lot in stock.........
    • We need to identify the movement to help you, but the oldest of these Rolco watches use Aegler-Rebberg movements that lack a calibre number and are very difficult to identify. You may end up having to make or modify a stem to fit . Post pictures of both sides of the movement when you have it and the size of the movement and hopefully it’s one that has a calibre number.  Gruen used a lot of the same Aegler movements at the time and it’s worth comparing your movement with those if you can’t find it labeled as an Aegler or Rolex/Rolco calibre. Best Regards, Mark
    • Onlly a pro's eye would notice that OH, you've still got it old fella 🙂
    • The triple lobed spring, as you suggest needs to be rotated to remove it or replace it. Suitably shaped pegwood should suffice, but tools (shaped as you describe) for the purpose also exist.  If you have an assorted of replacement springs, a trilobe style KIF spring of the right size might fit.  The other spring securing the jewel also needs rotating. There is a slight opening in the setting at about the 5 o’clock position in your photo and one side of the spring should be able to be removed  there when rotated into position.  Hope that helps, Mark
    • As an update, it transpired the setting on the balance side, with the jewel had one flat end and one curved. When I rotated it enough it popped out. The chaton was entirely conical and a tricky customer but once lubricated and dropped back in I put the flat edge in first and poked it in with the peg wood tool mentioned above (I made it with flattening off the end then sizing with a pencil sharpener before poking a hole in the end) then rotated and it went in well.    For the other side, magnet searching for the spring has been fruitless.    thanks for the link to the other thread
    • Thank you. It didn’t look rusty. For sure old.    Female part was inside the movement, and when I pushed male part, it got broken. I didn’t apply grease. Here is the photo.      Could it be that male part is too thick for some reason?
