i'm not sure if this is the correct forum to post this, but does anyone have a part number for an ETA 2783 date wheel? i need a 6 o'clock date wheel - where the numbers are turned so it can be viewed at 6 o'clock instead of 3 o'clock.
is this info published anywhere?
and better yet - does anyone have this part that they can live without?
This might help see PDF.
496_ETA2750,1,2,6,4.pdf
Also found on the bay for approx £35
Ebay No. 231835563627
Don't know what Country your in but if UK try contacting Cousinsuk or if America try Esslinger. Failing that try Ebay by typing in Eta 2783 watch and see what comes up. Several manufacturers may of incorporated this movement.
Tony
Sent from my SM-G900F using Tapatalk
good info guys. that movement on ebay is already on my watch list - and it comes without the date wheel.
after work, i will check out esslinger's and the other top suppliers.
i called borels - they will get back to me. esslinger lists only ETA quartz movements. cousins has auto ETA movement info, but not for the 2783.
i'm gonna try ofrei.
well, i got what i needed. ricardopalomino (louis) suggested i contact k. sudarson from swiss movements k. sudarson. sure enough, he has them (used). $14 plus $2 shipping. for those of us who might run into this at any time in the future, you will need to know if you need a flat or convex wheel.
i believe i need a flat one. now, i have to get a movement.
Edited by ramrod
