]I dunno , but those sure look nice .
I've been , if not obsessed , then in a Mad Men watch phase . I have recently acquired a few Waltham's , Organa , Hamilton , and others .  This Waltham came out real nice after I serviced it , cleaned the case , sanded and polished the crystal , and installed a nice vintage expansion band I had in my stash .
  The Organa is also nice after a service and case cleaning .
Nice watches guys and great job both. I have a question for Bimroy, are those re-cased movements and if so, are they all ETA 6498?
Cheers,
Bob
Gidday Bob, they are recased movements. They are Waltham 6S movements that I've built up from parts and given a new home. I pick up old movements off the likes of eBay, mostly with the standard broken balance staff, fix them all up and eventually re-case them. Some go into pocket watch cases and a few of these 6S's end up as wrist watches. Maybe a sacrilegious practice to some, but it also means that these 120+ year old movement continue into the 21st century.
Nice job and beautiful result, bimroy. I'm curious about the cases though. Are they made for those movements or are they the regular ETA 6498 type, hosting your 6S movements? I'd love to do at least one of those now!
Bob , if you or bimroy ever do one of these conversions , please take some pics as you proceed and share them with the rest of the members .
bimroy , these are truly handsome timepieces that I wouldn't mind owning .
Aloha , Louis
Hi Bob, the cases are for an Eta or the Chinese seagull movement. They are a polished stainless steel case with a glass back which expose's the damaskined movements. I just experimented a bit and machined up a movement ring out of nylon (the stuff that the race car people make suspension bushings etc out of). I also had to make up a winding stem to fit the Chinese crown and the Waltham movement. It's not too difficult, just a bit time consuming. I've made three of them so far and likely to do another if I can't find a home for some of the movements I've got rolling around in the bottom of my parts draw.
Awesome and thank you for the tip, Bimroy! I don't have a lathe so I'll probably use a less elegant solution if possible but it is good to know the regular ETA cases will be good without modification. That opens a new door for my tinkering! Much appreciated.
Cheers,
Bob
PS. Not to worry, Louis, if I do, I'll post what I did!  :)
ah, yes! a second chance for orphaned movements. what a great topic. i always wondered what sizes would work for a wristwatch.
those watches are beautiful. you can't beat the classic looks - either wrist or pocket movements. they had so much style.
that waltham that louis has reminds me a bit of a 50's hubcap.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
