Hi guys,
I'm trying to find a Tonneau shape crystal for a guess g75615g watch. It also is curved/concave and my local people, including crystal fitters, won't do the job. Any suggestions as to where to go from here? Where can I find an equivalent?
I don't mind plastic or mineral glass...it does go in glued.
Thanks in advance,
Cheers,
Bob
PS. Anyone ever heard or done business with Zugoo.com? Sorry about this other non related question! I do appreciate an answer though!  :)
if you want the best of the best,  William White will custom make a glass one for you for about $20.
he has made numerous crystals for me and they are glorious and perfect.
he is a true master.
attaching a pic of his business card.
Todd
