I have a Patria 15 jewels with 921918 stamped on movement. I opened up the mainspring barrel and it has no mainspring. Anyone have any information on what mainspring I might need to purchase?
Thanks
Pocket watch movement or ordinary handwind movement? It will make that so much easier with a picture or what movement it is? If i look at Patria 15 jewels. 921918 is probably some kind of serialnumber?
As always when it comes to watches. Can you post a pic to help identification ?
I will post a picture this afternoon. Thanks
I recently read that Patria and Omega have some relationship. So maybe you can find something there?
