I had almost completed my first strip, clean, lube and reassembly. I was servicing one of my vostoks with a 2416b automatic movement. I got it almost totally reassembled. When I put the rotor back on I noticed it didn't turn quite as freely as it should and was rotating the stem as it wound. Which I'm pretty sure it shouldn't do. So I go to strip it down and find where the resistance was coming from. When I removed the auto winding bridge, the reduction wheel upper pivot was stuck in its jewel. Not thinking, I slid my tweezers in between the wheel and the bridge to try and pry it out of its jewel. Needless to say, I broke the pivot off in the jewel. I guess I found where the resistance was coming in.
I guess I'll chock it up to a good learning experience. The worst part is that now I'll have to buy a new movement to replace this one. They aren't expensive at all really. But shipping from Russia (or the Ukraine) to the US takes ages. Which I guess will help instill a little more patience for the next time.
Here are a couple shots of my "handy" work. Sorry for the quality, only had my cell phone camera available.
don't take it too hard,
there is not a single person who does coa's who hasn't experienced that.
that moment when you realize, darn, i shouldn't have done that!
live and learn.
at least it wasn't someone elses watch!
Todd
Thanks. Another saving grace to having done it to this watch (aside from it being my own) is that it can be wound manually. So I can still wear it while I wait for the replacement movement.
If this is your first strip and clean I congratulate you. Most people would start out on a small alarm clock or a pocket watch sized movement. You have done extremely well and anybody can break a pivot so don't beat yourself up.
I'll second that!
We've all done that, so don't be to hard on yourself. You have done well in tackling  such a task. We all learn by our mistakes. Those Russian watch movements aren't made using the best of metals.
Thanks Mark! I would've chosen a less complicated movement for my first service. But I figured this watch was the most in need of it. Live and learn I guess.
Thanks oldhippy! I had always wondered where they were cutting the cost to be able to offer their watches at such great prices. I guess, now I know.
