Hi Everyone,
I'm in the process of servicing this for a relative and have noticed that the escape wheel lower pivot is broken - I suspect that this is why it hasn't been running for about 50 years.  So, ideally I need to source a replacement - the problem I have is that the movement has no obvious manufacturer or Caliber marks - other than those that I've mentioned below.
The movement itself is stamped with the word DÉPOSÉ and the numbers 6 and 9 together.  There is also a number on the movement and, interestingly, the case - it is 55709.
The ratchet wheel and the crown wheel are, unusually - well, in my relatively limited experience, both secured through the arbour by a sliver of what looks like brass, rather than a screw.
Any guidance would be hugely appreciated.
Best Regards,
Steve.
post-1851-0-70551900-1456266250_thumb.jp
post-1851-0-69262800-1456266253_thumb.jp
post-1851-0-70360700-1456266256_thumb.jp
post-1851-0-72517800-1456266260_thumb.jp
Déposé is a french word which mean "registered" , probably reference to a patent ; it will be a miracle to find parts for this movement, but if you have a lot of junk pocket watches and some luck ... The other solution is to re-pivot the escape wheel ; never do that so i don't know if it's practical.
Unless you can find a donor movement restoration is going to be very difficult. Someone with more pocket watch experience might be able to identify the movement.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
