I did dissemble my Tag Heur to clean up and the plate of the date come of the wheel beneath the plate I saw they used the glue to stick together . I try to use the crazyed glue to stick back but they wont stick !!!. I try to use the GS hypo cement it does not work either . I dont know what kind of glue they used for it . could you help me !!!
thanks
I show the pics for you can see it
post-1739-0-42746100-1456231804_thumb.jp
post-1739-0-91056400-1456231815_thumb.jp
post-1739-0-54278500-1456231828_thumb.jp
That is weird, I would have thought they would have done something else, like "rivet" it to the other wheel....maybe you can to that with a staking tool?
I am surprised they used glue. However the glue that will stick anything is JB Weld it dries black but for hidden parts is sticks real good BUT a real B*gger to shift when dry.
sorry to tell you tonychu.
there is not a chance in the world that those are tag parts.
on the upside clockboy is correct, JB weld will work.
make sure the parts are clean, grease free, and rough up the surfaces a bit to get a good bond.
get the alignment right the first time because as stated above it is pretty permanent.
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
