Omega 354 : Broken Balance Cock Screw
frenchie
Hello,
I have an Omega 354 Bumper movement and the weirdest thing just happened: I stripped it, cleaned everything in the ultrasonic, and when putting it back together, all the way to the balance wheel, the balance cock screw just snapped.
I had it in a couple of turns, it was going really smoothly, there was no resistance so it was clearly in the whole, with the thread caught, and then I thought I slipped but no, the screw just snapped. There is a bit of a lip left so I'm hoping that I can take it out....
What is a bit strange is that I'd undone the screw when stripping the movement, but had also put the balance back on the movement to clean it, no problem at all. I had also removed the screw again to put the movement back together and all of a sudden, SNAP.
I do clean the screws in the ultrasonic, is this a no-no ?
In the meantime, I also have to look for a new screw... sigh... Always something...
Hi Frenchie,
Sometimes screws do that due to either manufacture defects or fatigue. Sometimes a defective screw doesn't show it until the very end... I guess you got lucky there. It happened to me with a brand new Seiko movement right out of the box (screws are screws no matter what movement and/or manufacturer). I do clean my screws too and never had a problem.
Will you be able to fix it? An Omega is a nice watch!
Cheers,
Bob
  • 3 months later...
Follow up :)  Better late than never.
I found a screw on the Internets and the watch is back together ticking happily.
It was a pleasure to work on. Top notch quality from my perspective (except for that one darn screw), all the parts just go together right. It's the nicest watch I've ever worked on! Pictures coming up soon.
It's also my first bumper watch and for some reason, there is a weird satisfying feeling having it on your wrist and feeling the gentle tap of the weight moving around. I told my dad I'd give it to him unfortunately... He paid for it, that's his excuse for wanting it back...
BUT I have another one that needs quite a bit of TLC that I'll be working on at some point in the future :)
Well done Frenchie.  I'm a fan of bumper watches, I fully understand what you are saying regarding wearing it, and totally agree with you.
Regarding the broken screw, someone before you has probably over tightened it and stretched it beyond its elastic limit.
  • 9 months later...
More follow up....
I managed to loose all the pictures I had from the working movement I had fixed up.... And I gave to my dad for Christmas so that's that...
I have started working on another one, in much tougher shape, that somehow still ticked when wound a couple of turns:
- one screw broken right at the bridge level (automatic bridge) : fixed with a bath of alum powder overnight
- 2 missing screws... WTF???? one for the barrel bridge, one for the main bridge.... I have to source those
- one missing dial screw: I have to source that one too
- one broken dial foot: the dial is not in great shape, I'm too scared to ruin it to try to weld it back on... I'm going to try epoxy and see what happens
- broken regulator: I have a replacement
My next question is about replacing the regulator: sometimes it is attached with 2 screws on the underside of the balance bridge, but in this case, no screws, nothing... How am I supposed to replace it ? Can I just push it on ?
Omega screws are a little tricky to find on Cousins but the parts list is here (330 is the base calibre, you can also find the 352 special parts if needed) https://www.cousinsuk.com/PDF/categories/1354_Omega 330.pdf
Barrel bridge is screw # 2003, so search for part Ome2003 - not cheap at £7.74, but you may find on ebay etc. Dial screw is 2501 - same price.
Gleave lists Omega screws at £4, but don't have these on line - you could call them.
To fit to regulator, I believe you have to remove the balance jewel setting by removing the horseshoe clip on the underside of the balance cock.
that what I feared... darn... This is going to be a challenge...
Thank you for the screw reference, I see we share the same sources ;) After I'm done I'll need to find a couple more of those movements just so I can use all my spare screws (they come in packs of 5)...
  • 5 months later...
On 3/14/2017 at 6:08 PM, StuartBaker104 said:
Really not a big deal - a lot easier than removing the cap jewel for cleaning
I finally got all the parts I need... and promptly lost the horseshoe clip thing. It flew to outer space never to be found again. I feel like there is a technique to get it back in place but I can't figure it out :( are you supposed to slide it in? or something else? Any tips would be greatly appreciated!!
I did it!!!! The clip is back in place!!!! I only spent about 15 hours trying to put this thing back in.... A great learning experience overall, but also frustrating that it took so long. It was good practice to get my hands to stop shaking :)
Now I need to put the hairspring back on the balance cock, clean all the parts, and get the watch back together. I have all the parts hopefully.
My one last challenge with this watch is going to be fixing the broken dial foot...
    • Thanks Rich, its really not that difficult to make them, simple ones anyway. Cousins didn't have the part though i could find it on ebay at 6.50. I figure i earned about £1.50/ hr . It paid for the diamond files i bought.
    • If you look at this thread, you can see I had exactly the same problems with balance springs with 2 prongs on a Smiths 627. The slots in the chaton were not big enough to get the ends of the spring out. I had to bend them to get them out and back in. Not ideal. I don't fancy having to do it again as they could easily break, and where would you find replacements? I didn't come across the 3 prong type.
    • I visited the Breguet Exhibition today. https://www.sciencemuseum.org.uk/about-us/press-office/rare-timepieces-unveiled-new-display-science-museum The Science Museum now holds the collection of "The Worshipful Company of Clockmakers" - "The collection includes more than 600 watches, 90 clocks, 30 marine chronometers and a number of fine sundials and examples of hand engraving, mapping the history of innovation in watch and clock making in London from 1600 to the present day." It's well worth a visit. They have some amazing pieces by the likes of Harrison, Breguet, Tompion etc . I've visited twice before but decided to go and see the Breguet Exhibition. Maybe I was expecting too much, as on reflection, "More than 20 extraordinary timepieces designed by inventor and watchmaker Abraham-Louis Breguet " isn't going to take up that much space. In reality, it's just one cabinet. But, Oh those watches, stunning 🤩 , e.g. (No 1297 was made for George III and is valued about £1m)   I tried a couple of pics, but with subdued lighting and taking through glass, they aren't good. I like thin hands on a watch - how about these (I think this is a split second chrono)   And this one, with all it's complications, is only 10mm thick !   What I found very interesting were a few very old machines for making watch parts, like this 17th Century gear cutter. The disc below has concentric rings with holes in, so that is can be set to cut varying teeth numbers.
    • Firstly sorry for poor image quality I only have an iPhone for photos.    Im working on a 512 movement and I’ve had some trouble with the “jewels”. I’ve got the metal one out, but when I tried to put it back the three sides of the spring seem to need pressing all at once to fit it as there are three “holes”. I get two corners in but as I go for the third the first two pop out! Constantly I’ve lost the spring. I’ve done the similar ones on seiko movements without trouble. Assuming I find it/a replacement, what am I missing!   on the other side with the only ruby in the movement is a setting with no “gap”at all. How do I get the spring out, and of course get it back in!    What am I missing!    thanks in advance.    Rob
    • Links like that are the reason I routinely donate to the Internet Archive - they are the last safe house for a tremendous amount of useful info that is otherwise lost.
