Omega 18Spb Lift Angle
Chainstay
As I am a gear-freak I just bought a timegrapher to test my watches (and my skills) after servicing.
I also just bought a pocket-watch on an internet auction, rather cheap I think, and I believe its equipped with an Omega 18SPB-movement.
Now I need to know the lift angle. It needs servicing and I really would like to have a before-and-after assessment of the movement.
Does anyone on this superb forum know the lift angle? I did search the internet of course but couldn't find it.
Besides that I'm planning to get in into adjusting my watches meaning hairspring work and so on (starting of course with inexpensive movements).
Pauli
Do not worry too much about it. Even if you leave the default of 52° the instrument will still indicate daily rate and beat error, and show the general pattern correctly. Amplitude is only affect very slightly by having set the wrong angle, as you you can find yourself easily. Edited by jdm
Thanks, I'm satisfied with knowing that it doesn't mean a lot on determining daily rate and beat error.
And syfre: I have been watching this video, but I don't think the timegrapher I bought
has the same features regarding calculating the lift angle by fixing the amplitude? (to be honest I don't really know because I haven't got it yet). Even if it is a feature I think it's a rather complicated way if someone had the correct figure (lazy as always).
No it doesn't do that. It's a very basic model.
I have the same device and I can tell you, it works. Use the  menu/speaker button to jump into the menu, where you can adjust the lift angle. Nevertheless it's not that easy to use, as you always have to leave the menu and go back again until the value of the amplitude is ok.
Pit
I stand corrected, the method in the video works with any timegrapher.
However, for a movement under test is it very difficult to visually determine the amplitude at which it is oscillating without using a slow motion camera. For example the video says to bring the amplitude to 180°, but from my observation they brought to approx 175°.
Edited by jdm
    • I'm guessing, but this commercial demag machine maybe produces random magnetic fields to re-randomise  the iron particles. So heres one for you, synthetic rubies are coloured predominantly with chromium oxide . But natural rubies and old synthetic watch rubies were also coloured with iron oxide in higher percentages than chromium oxide. Which gave them a degree of.................🤔
    • I've never had a hairspring distort on me by passing the movement or just the balance in a plastic pot over this demagnetiser. Have you seen how fast a cleaning machine spins to spin-off fluid and that does no harm to a hairspring. I was a little concerned when I first used it, thinking it might be too strong, but I was wrong. It is strong, but it does no damage. I pass the part over the demagnetiser and keep going for about an arms length, so about a metre, to properly demag the part.
    • I don't think you would be able to find spare parts. Your best bet would be to get a new movement from eBay. https://www.ebay.com/itm/256508500506?itmmeta=01HY3M863PSA61GK7B859QCWTE&hash=item3bb9191a1a:g:ubgAAOSwrJJgPP-s&itmprp=enc%3AAQAJAAAA4DxWhpiQiz2ZjKpm3PS%2FHPh4IafsSzMWEobc2q4qQWgPGMZ8kCR8y2PRsm7GE31FjeSDYSWcEyGlrpZEdQyyzOSgsgsaPjbP7dYmK8r49Nh%2BEtSqDDIZ8Tbp3vvX035fFXgcjc1GEH8l%2FOWJ9aTeWNGzeBgUwqyhJ3ZSXji50TQr6rd38Sqwaqsj2oc51UVKqqIKySKTfxVB7X09EXcJsmeYc5GCdVODNkb02q2RsxfSIzpgl9dFCmW1Ih%2BPg2j2NziSELg5AfaHl%2FPU2Zn9fNnoVN1Z1NUAREyh2BCubcWC|tkp%3ABk9SR_bhoPTwYw
    • Here's a thought. Try unscrewing the bezel and the crystal. If you have one of those sticky balls for undoing casebacks, I would give that a try.
    • Last week I noticed my Eco-drive's second hand was stopped at 12 o'clock. I left it in the sun for a few days and no change, so I figured it was time to replace the rechargeable battery. I've had this guy for at least 15 years. Replaced the battery and the seconds hand moved to about 5 o'clock and stopped there. I let it sit for a day in the sun, no change. I took the battery out and tested it, and it's at 1.4v. The old one was at 1.0v. I'd like to test if it's charging. I've been looking around for diagnostic info, but only been able to find the owner's manual. Anyone have a reference for it?
