Watchmakers Lathe
madchops67
I saw this on the Bay for $200 and never got an answer for the size coletts which now I think are 8mm. It's a American Watch Tool Co. Lathe, and when the seller dropped the price down to $149.00.... I had to pick it up. Can't wait till it gets here considering its my first...this is my. gift from my girl [emoji173] Anybody know about that chuck on the tail? 69ddf9a054cd6a081a11562a18c097eb.jpg1bdc0fd8b8d071b6dd709df9421745a1.jpga559e5532d64cf6506bda725786b30ff.jpg96c2832eae18eb3404c392d3167e416a.jpg364958b5885080b8d0a3384ccb19ac3c.jpg244798157550f155011773b2c71e65fd.jpg
Sent from my SM-N920T using Tapatalk
The collets have different screw threads so you will need to know what the manufacturer of the lathe was. Providing the bearings are OK it could be a good buy.
Clockboy, Thanks for the information. The seller listed the lathe and motor as working condition and as should, he also tested the speeds of the motor. As far as the collets I was given a link to a thread on this page referring me to a great page with information about the collets and other lathes with the same manufacturer. Can't wait to start turning blue steel and practicing.
The collets have different screw pitches so you will need to know who the manufacturer of the lathe was. Providing the bearings are OK it could be a good buy.
There is a comparison chart for the collets available on the net see below link.
http://www.lathes.co.uk/collets/
Clockboy, that link you gave me serves well and I could definitely use it...thanks again!
Ok when up & running check for play in the bearings & also check that the two ends are centred with each other. This is really important also check this book out I found it really useful
The Watchmaker's and Model Engineer's Lathe
by Donald De Carle
by Donald De Carle
I'll make sure to check that. Also, thanks for all the information...very much appreciate it. I will keep you posted.
Yowza!
If this machine is functional, has good bearings and lines up well, you got a real deal. So what if it's over 100 years old :-) At $dayjob, we have some production machines that are still in use that are almost that old.
I hope that if I do need to replace the bearings, I can find them. As to how old it's is, I don't have a clue. And the chuck on the tail I've never seen....still new to these
If the end is split & tightens then it is a button or crown chuck. If it does not tighten then it is a box chuck that takes a wax chuck shaft.
The size of the collet suggests it is for a Boley 6 1/2 mm (0.213") or a Wolf Jahn 6 1/2 mm (0.212").
Clockboy thanks for the info, I'm going to do some research and see if I can locate some. It's a real small lathe.
Clockboy, seems like those 6.5 mm collets are going to be a hard to come by. So I'll just keep an eye out for a good set on ebay, but the lathe and motor are good to go...everything is lubricated. Thanks again! 3569e124d7a8e1739d655a342fca1bb9.jpg
I like the nice solid bed of the lathe. I would contact http://pennyfarthingtools.co.uk
He normally has lots of collets in stock. The guys name is Macomb. He does not keep his web site up to date so contact is the best way.
Thanks again Clockboy for the information. I contacted them via email and let them know what I'm looking for...so hopefully they'll give me a good response.
    • I also agree with @mikepilk and @Waggy. Your readings look good. The amplitude drop between the horizontal postion and the vertical position is nice and low (only 18° difference).  The delta of 17 sec (-3 to +14) between those positions is absolutely ok. If you really wanted to improve on this, I think you'd have to look into the poising of the balance wheel (not the spring, which looks perfect). But that's a total overkill for this kind of movement. Leave it be.
    • I've just finished refurbishing a Memostar Alarm with AS 1931 movement (same as 1945 but with date and running at 21600). I was also surprised how many parts are available at Cousins. Like you, I was missing the alarm stem (Cousins stock them) and I needed new crowns. It's a nice simple movement for an alarm, easier to service than a Seiko Bell-Matic. BTW I made a note in my Servicing spreadsheet: "Pull out winding stem before removal".  It may have just been wear on my movement, but I found that the yoke could move out of the clutch if the stem was removed in the normal position (like some ETAs).  You might find this interesting
    • I picked up this alarm watch at a flea market several months ago and recently decided to investigate.  I am not finished, but well on my way. As you can see, there was significant water damage.  Running these parts through my L&R cleaner was not enough to clean them, so I did manual cleaning with one-dip and cotton swab (the dense pointed kind).  The wig-wag was stubborn--the two gears would not release from the plate.  I soaked it in Kroil overnight and that did the trick. There was some rust on the balance staff, but not actually on the pivots themselves.  Nevertheless, I chucked it a step-chuck on my lathe and burnished the pivots. The watch is running and I have confirmed that the alarm drive train is functioning.  Since I am missing a stem for the alarm, I have not done the final assemble of the alarm components.  Surprisingly, there are lots of parts available for this movement on Cousins.  I will probably get a couple of stems and maybe some other parts that I deem necessary. The watch is running at weak amplitude (about 190) and shows some poising issues.  I will work on that. The last two pictures are after partial reassembly.
    • Hello and welcome to the forum.    Enjoy
    • Exactly!  It may not really be a joke, but the actual truth.
