I quite fancy putting a domed acrylic crystal in my diver just for a different look and for a bit of a change. Not bothered at all about it being waterproof as I have no intention of swimming or anything while wearing it. I just wondered whether the acrylic crystal should just fit straight into the case and remove the existing rubber seal. I have just been experimenting today as I found a crystal that fitted into the rubber gasket and it seemed quite secure and looked good too. The opening with no gasket is 29.33, what size crystal should I aim for if fitting one directly into the case?
I have been looking at some on Cousins site but they only seem to do even number sizes. So I could get 29.2, which is too small or a 29.4 which is the next size up.
Reckon that might squeeze in or is it too big a jump?  You are right they are not expensive so I could just order one or two to try first I suppose.
How close to the size stated on the packaging would you expect a new acrylic crystal be? I ordered a few "cheap" ones to test for size before I buy a good one. I thought it made sense.
I ordered a 29.4 it actually measures 29.2.  For another one I ordered a 28.8 it actually measures 28.6. So I am none the wiser.
I know they were cheap and it's not about the money. But how many do you need to order to make sure you get one the right size?  It's not such a problem when they are a pound or so each, but if you are spending say, £6 or £7 including postage for one it seems rather wasteful. The old adage "you only get what you pay for" seems to fit the bill. I imagine that better quality ones like the Sternkreuz will be pretty close to their stated size?
