I have reassembled my Seiko 4205 and am almost ready to post the pictures of the rebuild in the walkthrough section. It went together fine and was running but needed a little shake to get it going, I noticed that the balance was not looking quite as lively as it should. A close look revealed that the hairspring was clinging onto the balance cock and the coils looked bound up. Now, I will be the first to admit that my oiling skills are not quite there yet, but I knew that I hadn't put so much oil on that this could be the problem. I have taken the balance back out and held it close to my compass and the needle is deflecting so I assume it is magnetized. Actually, I held the rest of the movement near the compass too and it sent the needle spinning like mad, so the whole thing must need demagnetizing. I have noticed that Cousins stock them for £1.95, or you can get the Bergeon one for around £45! Now I am always one for a bargain but are the cheap ones ok, anyone here using one?  Obviously I won't be buying a Bergeon one anyway but I wouldn't mind paying a bit more if it was necessary.
While I was at it I "tested" most of my tools and found they are magnetized, as well as another couple of watches that I own. I am wondering whether it would be good practice to demag watches as a matter of course when servicing them and periodically doing the same with tools I use a lot. What do you think?
Looks good to me. Thanks Geo.
After another look at the Cousins one, I saw that it was really small, think you'd struggle to get a decent sized watch through it.
If that is a magnetiser/demagnetiser with a hole through it that looks like a set of steps, it is not for demagnetising watches. It can be used to magnetise the likes of screwdrivers to allow them to hold screws, then demagnetise them afterwards. With this type demagnetising is done by rattling the screwdriver in a rotary motion inside the demagnetiser.
I have used a Chinese Bergeon clone (the £45 one) for the last couple of years and it works fine, costs a lot less & is probably built in the same factory as the official Bergeon one.
As for the 4205, I fixed up one for the boss last year. After thorough cleaning & demagnetising the hairspring coils continued to stick, so I gave up and put in a new complete balance. It now running fine.
Seiko hairsprings are a pain to get working properly. They are very tight and the springs are very close to each other. That is at least what i have found out?
I have ordered one up. Hope it fixes the problem. Done a few of these but never had a problem like this.  Maybe the previous owner of the watch worked on the large hadron collider or something.
My demagnetiser arrived today. Swapped the plug as it comes with a two prong plug, gave it a go and it lasted all of the few seconds that I had the button pressed. The button is now u/s, I took the back off to have a look and the + wire that goes to the button has de-soldered itself. It's obviously burned out, as it smells. It is 110- 220v so was it ok to plug it straight in, or have I had a Frank Spencer moment?
I'm wondering if it was what is called a dry joint, that means that the solder hasn't fused with the wire/tab properly. There is a possibility if you solder it properly it will still work. Check the transformer wire insulation and see if it is burnt, and if it is it's a bin job.
When using this type of demagnetiser, the button should not be held down for more than a bout five seconds while drawing the movement away from it to a distance of about two feet.
I have had mine for about five years now and it still works perfectly, I think you have just been unlucky.
Might have had the button down for longer than 5 seconds but surely it would be ok with that?  The button is destroyed, it has melted a wee bit around it's base where the solder joint was.
Other than that there are no more burned wires or anything. I was thinking about trying to find a new button from Maplins and giving it a go or do you
think the whole thing will be up the creek? Got to be worth a try for the price of a push button.
I can't say without without seeing it and testing with a meter. Take it to an electrician if in doubt.
I went looking for a new button at Maplins and they keep the exact same one. Just soldered it in and it's working fine. I reckon it must have had a dodgy button fitted.
Anyhow, back in business now and going to get demagnetising.
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
