Chronographs
chadders1966
Hi
I posted a while ago asking for advice on buying a chronograph to take apart and learn on. Well I ended up going for quantity rather than quality and got the attached 3 inexpensive ones instead. Photo was taken on my phone so a bit fuzzy sorry.
On the left is a really good condition used Poljot 3133, similar to a Valjoux 7734 I think. Then in the middle is the oddest one, I can find out very little about it. It's an AATOS DismasSSB automatic 3 register chronograph that I bought new for less than £100. The best I've been able to find is that it is a Chinese factory copy/clone of the Valjoux 7750 (or 7753 given the subdial placement). Lastly there is a new Alpha Daytona Paul Newman. I slightly regret buying this as it is so obviously an homage watch - not a fake as it is clearly branded Alpha, but it is also clear which watch it is meant to remind you of. Mind you, plenty of other, better known watch brands do the same. It has a Sea-Gull ST1903 movement with the slightly pointless 3rd 24 hour dial. I should have spent a bit more money and bought the 1963 with the 2 registers instead. The movement is Sea-Gulls version (legitimate I think) of the Venus 175.
So there you have it. I now have 3 mechanical chronographs, none of which I know anything about, nor do I have movement holders for any of them, and I know nothing about taking them apart, dealing with pushers, chrono hands etc. What should I do now?
Purchase a copy of this http://www.amazon.co.uk/Complicated-Watches-Their-Repair-Donald/dp/0719800900 and read it, also watch as many videos on the subject you can find, then.................enjoy yourself!
Don't forget to wright a report on your progress in the "walkthrough" section when you get started.
PS nice watches! :)
Thanks George
I've actually got a copy of that and have read it, but will need to read it again and more slowly. I've read posts before, from yourself and others, about it being important to have the proper movement holder with pushers for working on chronographs. If the AATOS is based on the 7750/7753 I could get one for that I would think as you do see those for sale. Cousins has a A*F plastic one for around £25, I wonder if that would be good enough, or if I should look for a metal one? And where would I find ones for the other two? I don't think I have ever seen one for either the Poljot or Alpha, or the models they are based on.
Stephen
Hi Stephen,
I'm very interested in hearing from you about how it all went, even the part of the holder which I still don't have since I don't work much on chronometers, just light stuff.
About the pushers, there are different solutions, including the pressed on and the screwed on. Some come with "C" or similar clips and some don't. You will know what type is in each of your watches as you go along if the study of the case -- and experience -- doesn't give it up. In my mind it is a short, interesting and careful learning curve but once you have it, there is nothing to it.
If you have any questions I'm sure me or any of our knowledgeable members will be able to help.
Cheers,
Bob
    • Hello, I am just starting to learn how to hopefully service mechanical watchs Right now I started by acquiring a bunch of tools and a first practice movement (ST36).  Since I got it last week I have been practicing disassembling and reassembling it (I don't yet have the tools and products for washing and lubrication as I estimated that the first step is the manipulation required for assembly and disassembly). To be quite honest the result have been interesting.  My first step was breaking the setting lever screw when I was trying to remove the stem (OK practice movement won't be able to set time, oh well). I did manage to mostly disassemble the movement (I kept the balance together, didn't open the barrel and didn't remove any jewels). I messed up the balance spring a bit when removing the balance (I think the impulse jewel was still in the fork or something). There was  a small tangle. I reassembled everything and surprise the movement came back to life. I disassembled it again and decided I will try to fix the hairspring.  So with lots of trouble I removed it from the balance and when trying to fix it I made more of a mess.  After reinstalling everything the balance won't oscillate (likely the spring rubbing on things, either the plate or the cock). Right now I wait for my second st36 and continue practicing while slowly buying what I need to wash parts and lubricate them.   Any of you think there is a chance I can repair that spring or find a balance complete for that movement which will cost less than the whole movement?
    • Hello, I am a software engineer and all day spent in front of my computer makes me want to do something more manual as a hobby. I like the mix of intricacies and basic technology of mechanical watches, the fact that such marvel could be built manually hundred of years ago fascinates me.  So I decided to combine the two and learn "watchmaking"  (between quote as I don't expect to ever be able to make a watch). My first goal is to be able to service a mechanical watch. My current status is that I am pretty good at breaking small parts in watch movements
    • Nothing special to the horological world, but this is my travel watch. For whatever reason, this watch has accompanied me through airport security more often than my appendix and gall bladder. I feel as if i need this with me as much as my passport.
    • Apologies for digging up an old post but I am thinking about doing the same. Can I ask the OP what medium he used on the wheel. Was it a sanding disc and polish and if so what grades. Thanks.
