Seiko 6105B Balance Jewels.
rogart63
Does anyone now if the jewels are the same top and bottom on this movement . My bad i mixed them up :) The balance stops when i lean it over to one end? Either i have mixed the jewels or the balance pivots are worn?
Are cap jewels installed right side ?
Found the problem? It was the hacking lever that moved when i leaned the movement to that side. Stopping the balance to move. Working fine when the keyless work is assemble again.
Edited by rogart63
    • Looks lint the teeth on the hour wheel aren't meshing with the teeth on the calendar intermediate wheel, maybe the hour wheel is sitting on top of this instead of meshing?
