Removing Balance Cap Jewel On Certain Watches.
I use pegwood for removing and replacing hole jewels and cap jewels into the balance cock and base plate. Lightly tap into place or push in. Used rodico once and had the same problem. Anybody having problems fitting screws, consider a Bergeon pin vice, not the ones you screw up but they have a sliding collet, if that's the right word.
Sent from my SM-G900F using Tapatalk
Seems there's more than one way to skin a cat...LOL
What kind of oil is best for cap jewels? I don't want to buy a bunch of stuff I'll never use. When I started to learn piano technology I was sent a bunch of stuff I never needed...ever. I'm going to order a set of 4 Oilers and if I could just get 1 kind of oil for now that would be great. If someone thinks I need more please tell me.
Thank you for all your help.
Dave
I sure jammed a lot of Rodico in under the cleat where the Novodiac Spring goes. I had a hard time getting apart after cleaning it. Now it's apart I hope the cleat gets a good cleaning. Of course, now the whole thing has come out of the bottom plate - etc.
I must say, however, my tweezer/pegwood technique is improving the more I handle this stuff.
Practice makes perfect - except with golf.
Dave
Sorry to hear about your Golf, Dave...I learned they had a defective batch of golf sticks at the place you bought yours...that's a no win situation!  :)
On the other hand and seriously, I believe you are doing just fine. It is all a learning curve and pretty soon you'll be handling those like a pro.
Cheers,
Bob
Thank you, Bob, for your words of encouragement.
I figure it's the little people who live inside the golf ball and control its flight that have something against me.
I actually surprised myself while taking apart the cap jewel for cleaning.
Perhaps I am coming off my plateau and climbing to another...
Dave
Dave, the cap jewel on either end is replaced the same way. Basically -- and the way I do it -- I grab the whole thing with either my tweezers or rodico (first the cap and then the case jewel underneath) and drop them in lighter fluid. I let them there for a while and shake them every once in a while (if there is a spring -- novodiac or some detachable variation) I drop it in the fluid too. Then, I take all the parts on a piece of watchmaker's paper (lint free) and let dry. Eventually I take the cased jewel right side up and put the oil in it and the cap jewel on top. They will be "bound" together this way. The final step is to drop the whole thing on the bridge hole where they belong and hold them with the spring.
Now as for the actual replacement when you loose one of them, you go by the caliber of the movement and order them accordingly. Check out this link so you have an idea of what I'm talking about: http://www.ofrei.com/page615.html#23561
I just takes practice and very important, your tweezers need to be perfectly dressed. I particularly favor #5 for most stuff. Of course, #5 is too thin and therefore not that strong for a lot of other work but for this and hairsprings are good. Remember than not all #5 are made the same...I use a good quality cheapo one for rough work and dress it constantly (I like doing that, it's a hobby!). For the real thing I use Dumont #5 Dumostar, hard, chemical resistant, antimagnetic and ...expensive.
One more thing, if using rodico, I roll an end into a fine sort of tip (thinner than  the cap jewel) and use it gently...make sure you have handled it enough so it is soft and sticky.
I hope it works...but I'm not a pro so maybe other people have better suggestions.
Bob
PS. The actual embedding of any jewel into a hole (permanent deal) and probably not a balance one unless we are talking about older or different movements, are done with a jeweling tool as CB said.
Hi Bob
Thank you for your lengthy and informative post.
It is the whole assembly that need to be replaced. The thing holding everything, jewels etc, in the plate. I'm told I don't need a staking tool for it since it goes in outside in and there is a limiting cleat on it.
I am away in Winnipeg just now. I look forward to oiling and replacing everything when I get home.
Thank you again
Dave
Hi ya,
It seems from what your saying the hole jewel and cap jewel fits into a flanged hole. If so you won't require a jewelling tool as the depth of the jewel is set by the flange. Push the hole jewel in first using a piece of pegwood then the cap jewel. Don't use a stake for this as it could damage the jewel or Where it seats onto. In other cases you will need a jewelling set. Keep an eye out on Ebay for a decent second hand set. A new set your going to have to have deep pockets for the purchase. Sending pic of my old Seitz set to give you an idea what to look for.b59d56b4c43f6dac6a955602ef353f9d.jpg
    • Hi can someone tell me where a can buy this chart for breguet hairspring frequency?
    • OK Rich, may be You are just a little bit more worried than really needed. Who am I to say, jus a newbie here but... Such a big forum will not collapse in any case, exept if the people loose their interest to participate. If something happens to the owner,  then senior members will be able to handle the forum. Let me show an example where one of the moderators of the russian forum (thow He was not russian), a man of great knowlage abd big heart, passed away in 2023. Thow His personal site is still working, the russians coppied the whole site to safe place here. I mean, all depends on the people and if they need to do something, they will find the way. Actually, the forum is place where people can meet and share. As a final measure, people can share their phone numbers and use Viber to comunicate, at least people who are interested to keep connection between each other.
    • Since I couldn't slow the machine down enough for my liking, I started off slowly with a higher grit.  I began (very lightly) with 1000 grit paper: https://www.amazon.com/gp/product/B07DTJBND1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 Finished with 3000 grit: https://www.amazon.com/gp/product/B07DTFSMT1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 Afterwards I went on to polish with traditional methods using felt & cotton wheels, with different grades of Dialux. Hope this helps.
    • Ok so there is barely any response happening . After this last attempt i think I'm just going to give up on it because very few seem genuinely interested or even bothered or worried what may happen in the future. ( if someone can set me straight I'd love to hear it ) I would think anyone into watches has heard of Roland Ranfft, how they grew to love and depend upon his site for detailed information. And not just that, he also had a view about Ebay and everyone that visited Roland's site knew exactly what he thought about Ebay, Roland's site also had a secondhand watch sale side to it.  If anyone here could have done anything to preserve his site and keep it exactly the way it was.........Would you have done something to make that happen ?  Its been pointed out to me but not in so many words  that I'm probably coming across as an insensitive p.rick, truly I'm sorry about that, i say it as it is but no malice is intended and yes clearly I'm putting my forum membership on the line here. I'll happily shut up about it now, I've done all i can.
    • Thank you so much for posting this!  Although this movement is serviceable, there are no service notes that I've been able to find.  This is a great alternative!
