More On The Harwood Watches
cdjswiss
For those of you who have read and were interested in my previous post on Harwood watches (the first automatic watch) here is another interesting example. This one was marketed by Blancpain in Barcelona around 1930. The hand setting is now done by turning the watch back and there is a four-cornered screw head (arrow) that turns against a leaf spring to adjust the pressure of the slipping clutch that prevents over winding.
Nice watch Colin, you certainly know how to get my attention. Does the back just snap off and are you going to service this one?
The back does indeed just snap off as does the font bezel. The movement is front loaded with two half-head screws to hold it in place. This arrangement makes it less dirt proof than the more conventional Harwood.
I have just done a complete service and it is now keeping time to better than one minute per day. The silver dial with gold numbers is original and has just had a light brush over to remove a little dirt.
Harwoods have a reputation of not running for more than 12 hours, but this is nonsense. The power reserve depends on the Schild movement and is well over 24 h. A mal-adjusted automatic winding system probably accounts for poor performance. But this one I have worn 16 hours per day and taken it off for the 8 hours overnight and it has not stopped since I began to wear it on the 1st January.
The Spanish patent number on the winding bridge is a mystery - some have attributed it to the back-setting feature, but it cannot now be found in any Spanish official record. It is thought that perhaps, although filed, it was never granted. The novel slipping clutch screw adjustment permits easy and stable over-wind protection. I wonder if this was a Blancpain add-on?
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
