Balance Tack- Small Project
steve855
Hello All,
I haven't posted much lately because I haven't really done much lately. I had some free time this past weekend so I spent it in my workshop. A balance tack is a traditional lathe project and I needed one, so I figured I'd give it a try. The base is 7075 aluminum alloy because that's what I had on hand in the desired diameter. The black transition piece is black acetal, and the tapered shaft is brass. I wanted this to be easy to disassemble so it would fit in a shallow drawer, so the acetal piece has a 0.187" stub on the bottom that's a snug slip-fit with a corresponding hole in the center of the base. The brass portion is a press fit into the acetal. The perlage/spotting on the base was just for fun. Looking at the photos, I could have spent a bit more effort on smoothing the brass taper, but I ran out of time. Sometimes I have more fun making and modifying tools than actually repairing watches. Probably because the tools are not so small!
Thanks for looking
Steve
  • Like 7
Marc- thanks, the perlage was actually not difficult. The base has a through hole in the center, I setup a pin this diameter in the drill vise with a crude paper washer slipped over it. The base was then slipped over this, allowing it to be rotated manually around the centering pin. I chucked a pencil eraser in the drill and spun it at moderate rpm, maybe 400-500.
I brushed a small amount of lapping compound onto the top surface of the base then started the first outer row of overlapping circles. With each circle I rotated the base by 1/2 eraser diameter, when the outer row was complete I moved the whole assembly over 1/2 dia with the Y axis and repeated this process until it was finished. It was fun watching the pattern appear, and no special equipment required, other than the mill/drill. I'll try to find a photo of this.
Geo- thank you, I don't have a dedicated watch workspace, so I keep all of my tools in a nice old Gerstner machinist's chest, and most of the drawers are shallow, so the ability to disassemble was important for me.
Edit- photo added
Edited by steve855
  • Like 5
    • That's the right technique Mal đź‘Ť If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
    • Hope you mum keeps on mending. I was adamant that I was going to get myself going after my stroke. I was only 52. I still have a lot of life left to live. Some people give up. Some people don't let it beat them. Your mum sounds like one of the winners. 👍
