Quartz Watches Troubleshooting Help
bobm12
Dear friends,
Lately I've come upon a few movements (quartz) from different manufacturers: Seiko, Citizen, Ronda, etc. They are all non working...or the hands don't move to be more precise. Now, I don't know much about quartz or electronic watches but this is what I do:
I test the battery and if it test good I test for a pulse.
If battery bad, replace for new one and test for pulse.
Now, some have pulse but hands don't move or some have no pulse and hands don't move. Either way I put them in the Horotec turbo:
and in both cases the hands will turn, forced by the tool. After this application they still won't work.
My question is: Where is the problem located for each case?
Pictures of a non working Fossil with a Ronda 515, new battery, no pulse and hands move when on the horotec tool:
post-253-0-45052300-1450183964_thumb.jpg  post-253-0-04251000-1450183967_thumb.jpg
I thank you in advance,
Cheers,
Bob
Thank you Steven! Much appreciated. Would the hands still turn when on the Horotec turbo if the coil is bad?
When the stepping motor and the train is ok then the hands wil turn. While testing the magnetism comes then from the outside not from the coil.
On calibers with an very low frequency, Omega 1353, the stepping motor get every second an inpuls. When you give an turning field from the outside then the gair train will be damaged!
I assume the turbo device works fundamentally the same as a demagnetizer, if so then it doesn't work through the circuit/coil, it simply generates a magnetic field that oscillates rapidly (more rapidly than what a watch normally does) it effects the magnetic stepping motor directly, causing it to turn 180 degrees to re align itself, at a rapid rate.
So in other words, yes, as far as I'm aware it does not matter the condition of the circuit or coil, it should make the hands spin all the same.
Kraai, I didn't know that the test could damage low frequency caliber. Thanks for the advice.
I use an acoustic device that pick up the sound of the pulse. When I hear a very faint pulse, that means the circuit is good but the coil is damage. If no pulse at all, then the circuit is damage but the coil is usually good.
The Horotec turbo simplistically replaces the internal circuit and coil to apply the magnetic field from outside of the watch. It doesn't just supply the magnetic field it supplies it at a very fast rate to allow you to see the hands spinning. Sometimes are advertised as miracle cleaning devices although they don't use the word miracle I'm just putting it here because it doesn't really clean it just spins the train possibly freeing up lubrication for a short time. There is no substitution for real cleaning which is disassembly same as a mechanical watch.
https://www.youtube.com/watch?v=v3dzx7CZJYU
Then a video on testing a watch without you do not necessarily have to have expensive test equipment like this.. Then he's testing a modern quartz watch and he's not familiar with older watches there are some differences.
https://www.youtube.com/watch?v=uIypsvp9D64
Some PDFs on quartz watches testing  theory.
http://www.witschi.com/assets/files/sheets/Knowledge%20Quartz%20Watch.pdf
http://www.witschi.com/assets/files/sheets/Witschi%20Training%20Course.pdf
I'm not sure if I understand what you're trying to say? Most stepping motor watches by your definition would be low frequency they step once per second or slower.. So that would mean using this on all quartz watches would be bad. I'm not sure the tester would even work on the 1353 for those not familiar the stepping motor is of a different design. A lot of the early quartz watches used sealed motors..  Then if the watch doesn't have a secondhand the stepping rate can be even slower.  I once had a Timex watch that If I remember right  stepped once a minute.
Bob you have a rather interesting question that can have multiple of correct answers. A very very long time ago I was at a lecture on fun and profit of quartz watch repair. So the individuals explaining about cost breakdowns like what would be the cost to completely service of quartz watch? Or replacing a coil for instance what is that's cost versus an entire movement? If you purchase the entire movement for less than a complete servicing you can just swap the movement. Or even the coil sometimes it was cheaper to buy an entire movement than just the coil. At $15 you really can't afford to do anything at all with this watch if you're making money other than just replacing the movement.
So at $15 obviously the watch was never meant to be serviced but I was going to recommend go ahead doing it anyway if the watch would come apart? After all were on a discussion group of people who like to disassemble things and you're not doing this for making a profit so for learning alone it's worth disassembling.
Then we have something very interesting the watch company Ronda has technical documentation. So at the link below are two PDFs the first one the datasheet Which has an interesting feature listed which I just going to quote directly from it "Repairable metal watch movement". So what exactly does repairable mean to this company? For that you need the second PDF 29 pages of everything. So everything is interesting way more than what you find in a lot of technical literature today. Basically everything related to the watches listed mechanical specifications, user guide, tools and how to service this watch. So starting on page 25 complete disassembly lubrication parts list. Page 27 all the electrical checks you need to do. Basically everything you want to know about this watch in one PDF.
http://www.ronda.ch/en/quartz-movements/quartz-essentials/ronda-powertech-500/caliber/515/
As a side note to what's ended up being discussed as a result, i would like to argue against treating a 'sekonda' for example, in the same light as we might treat a 'jaeger lecoultre'.
And I really don't mean be reckless and stop caring, but some 'troubleshooting' methods that we wouldn't in a million years subject a fine, swiss watch with an ETA or watch manufacturers own movement to, I think is actually perfectly adequate, acceptable, and effective when used on a watch with a hattori plastic pc21, or a miyota 2025 (or their varients). They're simply a different matter.
Edited by Ishima
Excellent post John, I will be having a field day with the 515 and all the documentation. It will be a very interesting and learning experience. As it is, I decided to put this watch into circulation with a new movement BUT, I'm keeping -- and using -- the old movement for "research". :) Much appreciated, your words and documentation!
@ishima: Thank you for the insight Ishima. I will keep it in mind during my journey into digital movements! :)
Cheers,
Bob
    • I wish to share my experience with thyme tea with everyone. Six months ago when I had my second bout of Covid, my chest was so congested that breathing deeply hurt. Coughing was pure agony. And with a 40°C fever that comes back every 6 hours when the level of paracetamol in the blood falls, I was willing to try anything.  Then I saw this video on YouTube and I decided to give it try. I drank a cup of the stuff and went back to bed. When I woke up about an hour later, I coughed up a golf ball sized lump of greenish-yellow phlegm. And almost immediately, all symptoms suddenly abated. 24hrs later, I was feeling perfectly fine. I repeated an ART test and it was negative. I started recommending it to some of my friends and many of them found it useful, although some claimed it had no effect. I had another round of Covid last week. I tested positive on Thursday and although the symptoms were very mild, I drank a cup of thyme tea just to play safe. And by Friday evening all symptoms were gone. I repeated an ART test and it was negative. If any of you read this, try it out the next time you get Covid or the flu. Let me know your experience with thyme tea. @watchweasol, you might like to take note of this.
    • The problem is where the arrow shows.
    • Why is it when that little voice says, "This is a bad idea," we always want to talk ourselves out of it? I had the low blood sugar jitters earlier, but insisted to myself that I'd be able to oil an especially tiny cap jewel on my friend's Omega 1001. With lots of concentration, I nailed it. But when I put the hole jewel on top, it was too much oil and it squoze out everywhere. It didn't spread on the cap jewel much thanks to the epliame I'd applied, so it was more than it looked like from the top. Back in the cleaner, dried, re-epilamed, dried. Time for a second try, but now I was more shaky even than the first time. "This is a bad idea," my brain told me. "Take a hike, brain," I said as I watched the oiler jiggle into my microscope's frame. And just like that, the jewel was a tiddlywink and flew out of sight in the blink of an eye. With a strong UV flashlight and the waste of a lot of time I did find it on my desk, but that's some stress I didn't need in my day. So friends, listen to your body, and listen to your brain when it tells you now's not the time for precision work.
    • I dont think Hector means there is an issue with the hairspring at the collet, only that the collet is not centered over the jewel hole. You can check this by unmounting the hairspring from the balance and recentering the collet with the balance jewel. If the coils remain undisturbed then i believe it unnecessary to dismount the collet and only adjustment at the stud is needed to bring the hairspring to shape. If any of coils have been accidentally bent then reshaping of hairspring separately would be required.
    • @HectorLooi Thanks.  I do have a microscope. But no camera to show what I see in it.  You are correct that some coils overlap. In particular the outside one where thr regulator pins go  overlaps the previous one. I will try your suggestion.  I am surprised that there is an issue with the collet as I don’t see how I would have messed that up.  I didn’t think the impulse jewel is damaged as I can check it in the microscope. I meant that when I put the balance I am always wondering if I managed to set it correctly in relation to the fork.  Thank you all. So I think I will take @HectorLooi advice and note that the hairspring needs fixing and go practice with my second ST36. In any case this one also has the setting lever screw broken in the setting lever.  I think I’ll also order a dial, case, hands and strap to make a watch out of that second movement.  I see a bunch of them on AliExpress or eBay.  Anybody has recommendations?
