Gucci 9300 Chrono Instruction Manual
watchmad
I'm looking for any instructions for this watch to reset everything after a battery change.
It's some complex series of presses on the 3 pushers and 1 crown but I can't remember the sequence and I've lost the instruction sheet that I had.
Any help would be appreciated  :geek:
post-1589-0-67837200-1447735313_thumb.jp
Thanks guys.
Yeah it doesn't seem to work using those instructions.
The movement is Swiss with 1 battery for the time and another battery for the Chrono functions.
I found a picture of the movement here: http://www.watchrepairtalk.com/topic/1112-gucci-9300/
I seem to recall having to press 2 buttons simulateously while the crown is out but I can't recall exactly.
I even sent an email to Ronda in Switzerland but got a fairly unhelpful reply..   but at least they did reply:
According your description we don’t have/had such movement in our sales program. But we know, that some of our clients added RONDA watches on their modules, which they have assembled to entire watches.
So in this case we know only the functions concerning the time indication. Please contact the watch brand (Gucci) for further instructions.
Unfortunately not.
The watch has 3 pushers and 1 crown and as near as I can tell, the crown only has 2 positions.
It has been many years since I had a battery in this watch but I seem to recall needing to press some obscure combination of the pushers after changing the battery.
  • 11 months later...
On 11/17/2015 at 6:36 AM, Geo said:
Welcome to the forum Watchmad. I suspect this may have a Seiko 7a28 movement in it, so try setting it using these instructions.
George.
I did spot this (incorrect) post of yours earlier and I had to chuckle to myself. :biggrin:
It's an easy mistake to make with these 7Axx clones, of which the Gucci quartz chono's are just one. There are other bone fide brands of 7A28, the most obvious being Yema, which use a (re-branded) Shimauchi Ltd V905 movement. The easy way to tell a 7Axx clone from the 'real deal' (without sight of the movement) is to check the increments on the LH minute counting sub-dial. Usually they'll go up to 60, whereas a pukka 7Axx only counts to 30 minutes. Plus they're usually 'Swiss Made'. <_<
    • Lots of rust on that hairspring Nev, would you even try to clean it up ?
    • How do you find the working distance from microscope lens to movement? Is it comfortable enough to get tools in?
    • Once you have the collet closer bits off, and the pulley off, there are two nuts on the spindle. These must be removed. There is a large nut in the back of the headstock with two holes, remove this with an appropriate wrench. The front large nut comes off too. The spindle now comes out- but wait- there's more! There is a spacer between the outer races of the bearings; the spindle will almost certainly come out "assembled" with both bearings and this spacer (it can actually come out front or back-ways with the large nuts off the headstock). You have to manage to press out the spindle from the rear bearing, get the spacer off, then remove the front bearing, now you can get to the key.   Imagining you get it all apart without causing any damage to the bearings, now the fun part starts. You must apply preload to the bearings, and this is a very tricky endeavor. Basically once you have the bearings back on, and are in the casting, you snug up the rear nut (one of the two) on the spindle, checking the play of the spindle with at least a 0.002mm reading indicator, until there is zero axial play, then just a little more, then snug up the second nut to lock things in place. Of course snugging up the second nut influences the preload, so you can go back and forth a few times to get it right. Too much preload and bearing life diminishes, too little, and you get poor performance, poor surface finishes, ball skidding, etc.   When I replaced the bearings in one of mine many years ago, I was surprised to find that the bearings were regular deep-groove bearings, but of a higher precision class than normal. I replaced with dimensionally identical angular contact bearings, class P4. In trying to set the preload, I just about lost my mind, so called Barden (the high precision arm of FAG bearing makers, and who made my new ones) and a nice engineer told me that the folks at Leinen were either crazy, or really good- he also said it's 100% A-OK to set up deep groove bearings with preload like this, but best is angular contact. In this bearing setup, the standard way to do it is to have a spacer between the outer races, and another between the inner races. Leinen has the former but not the latter, haha. His advice was to make an inner spacer. The trick is it has to be the exact same length as the outer spacer, within like a micron.  Then you just tighten everything up and the preload is set, because the bearings (the new ones) are ground in a way that they have proper preload in that situation. Easy. Sort of- if you have the means to make the other spacer!   Just to note- Schaublin does the preloading as Leinen did on these on their lathes using angular contact bearings. There is a procedure in the manual, where you tighten the nut until axial play is zero, then a certain number of degrees more. This works on their setup as the nut itself locks without a second nut, and they spent the time to figure it all out in a repeatable way.   I say all this not to scare you off from dismantling your headstock, just to give a heads-up what you're up against to get it back to where it was before.
    • Do, write a nice letter to Santa. I do all disassembly and assembly under the microscope. I consider it a necessity.
