Hi,
I'm a newbie to watch repair and would like some recommendations around balance problems I've encountered. Currently looking into Citzen Homer series of movements, trying to learn as much as possible,
Attached are two examples of problems I've encountered.
1) Missing jewel
2) Balance staff broken
So here are my questions:
1) Is it feasible to repair these problems?
2) What tools do I need and what brand of tools would you recommend to use?
Br Fredrik
Edited by FredrikP
Posted to early
Welcome to the forum.
Depending on the movement you may be able to buy replacement jewels either original or generic.
With the balance staff you'd need a lathe and a lot of experience to either repair or make a new one so again your
best option would be to just get either a new staff or even complete balance, again depending on the movement.
Thanks for response!
According to Ranfft dB for 1800 movement the replacement balance staff is Ronda 5209, just ordered it of ebay. What tools do i need to replace the balance staff ?
For the jewel is it possible to dismount a jewel from another balance and mount it on the one missing the jewel? Is the jewel mounted with shellac?
what happened to the jewel? In 1st pic it is there, in 2nd it is missing.
These jewels are available, you can also harvest an identical one from another movement. Fixed with a bit of shellac.
 You will need staking tool and plenty of practice, just to restaff this balance wheel properly.
 Many beginners are happy as long as their watch  runs and keep good time on wrist, posing the balance is next, so you need a tool for that.
I wouldn't recommend any of the above for beginners, cuz your looking at approx 1K then you might decide watch repair isn't your thing.
Your best bet is to buy a new complete balance, next comes regulating the movement.
Rgds
You'll need levers to remove then spring, then a roller remover for the roller and finally a staking set to remove the staff.
I've been exploring on the 1800 movement from citizen and currently have a couple of movements to work with. Two of the movements that i bought have problem with the balance as the pictures attached, and I want to explore fixing them.
Any recommendations around staking set that I should be look for?
I think at this stage in your journey your best option would be to get complete balances.
You can then look more into what's involved with replacing a staff on a test movement further down the line.
Ideally someone new to watch repair should practice on watches that do not require as many tools as you're going to need to replace the balance staff. Then ideally should practice on watches and learn how they work learn how to take apart put them back together learned what a balance wheel should look like when it's functioning and slowly build up a skill set before tackling replacing a balance staffs. Which is why typically most people will purchase a balance Complete as they don't have to deal with all the problems and purchase the thousands of dollars of tools that you really should have to replace the balanced staff jewels etc.
To avoid running two simultaneous discussions here is a link to somebody who's ask the exact same question about a staking set.
On the other hand, if you are already sure you want to invest not just time but also some €'s in tools, go watch some of the several available video's on the subject on youtube (and  watch them several times more until you can visualize the steps) and invest in the tools required.
The tools I used for my first balance staff replacement were:
- handlevers to remove the hairspring;
- roller table remover (lots of types available, but I used the Bergeon 2810)
- Clone horia tool to remove the wheel from the staff (best practice would be to cut the rivet using a lathe, but that raises the complexity level and the investment in tools..). I use the Horia clone with original Seitz pushers because their quality is better and I have them.
- Staking set.
We don't know what your skill level is, but if you feel comfortable giving it a go: by all means, watch some video's, work careful and give it a go! You're not working on expensive pieces, so why not.
I am curious about how exactly do you do this and why you did not use your staking set to remove the staff?
I find actually multiple sources of information are good. Like in addition to the videos books are nice in the absence of books websites where you can download PDFs of the book. So for instance the website below has lots of PDFs. The ones that you should be looking at would be 1945 TM9-1575 War Department Technical Manual Basically a training manual for watch repair. Then a little farther down  Joseph School of Watch Making. This was the textbook for the Bulova school of watchmaking and you want to download the entire book because you're going to need a lot of sections out of this book to replace a balance staff.
https://mybulova.com/vintage-bulova-catalogs
I place an anvil that just fits over the staffs shoulder in the bottom part of the tool to support the wheel as close to the staff as possible. I place a pusher that just fits over the top pivot in the spindle, mount the staff with wheel between them, carefully move the spindle down until it just clamps the staff and then give the spindle one sharp twist down. This gives me more control then using the staking set, but like with a lot of procedures: it's a personal preference. Also, I work under a microscope and the horia is easy to hold in one hand on it's side to give me a good view when placing the balance.
I found this video on youtube of someone using the same method:
Edited by caseback
Times Radical,  he's a rather dubious character lol.
 I guess Andy must have mastered restaffing at least ten years ago, and forgotten about all the practice mastering the task took him   . add ten years doing the same,  day in and day out , it would kinda  look as easy as one two three to you.
 Hate to be the one saying this, if you don't know the tools you need to build a complete balance, you wouldn't know how to restaff a balance.
The consensus here is;
A NEW COMPLETE BALANCE.
In case you are so keen to go pro and fast, Mark offers watchrepair courses.
We saw how supersonic VWatchie flew in less than two years.
Rgds
The video is showing how to do a particular Rolex staff. With some Rolex balance staffs the only way they can be removed is by pushing them out sort of. I was at a lecture once were somebody demonstrated basically push the staff until the rivet breaks with a very satisfying pop sound. This is because the balance staff is designed to break at the rivet. Unfortunately not all balance staffs will break like that which is why other tools are sometimes required. Unfortunately with the balance staffs are doesn't actually seem to be a universal perfect method and other methods may be required to avoid damaging the balance wheel.
As far as I know, a staking set, a platex tool and a horia tool (to name a few) basically do the same thing when used to remove a riveted staff from a wheel: applying force until the rivet breaks.
Balance staffs are made from hardened steel. I imagine that rivetting it will cause some fractures and/or some additional (work) hardening, both causing it to be more prone to breaking. That is what we are counting on when using the above mentioned method.
There is a possibility however that this method causes damage to the wheel if the rivet is too strong. So you wouldn't want do this when working on a piece you do not want to risk damaging. As I understand, using a lathe to cut the rivet is considered best practise.
I personally do not know any other method to cut a rivet other then using a lathe.
Perhaps some of the more knowledgeable folks on this forum could mention some more methods?
Unfortunately and watch repair there are a number of subjects that will result in extremely heated debates over procedural stuff and unfortunately this will be one of them. I am limited deliberately skip over some of the fine details that people like the bicker over and only look at a generalization of the minor problem of what I've quoted above.
In the case of a staking set or the platex tool Which I do not have there is usually a method such as image below a accessory device that is used to hold the balance arms down when the staff is knocked out. This is designed to prevent the balance arms from getting warped.
Then here's an example of pushing the staff out without supporting. Rolex uses this for some other watches because as the image shows the hairspring cannot be removed the staff has to be pushed out. But the balance staff has been designed for this purpose and the balance wheel will withstand the rivet breaking. Unfortunately not all balance wheels can have balance staffs removed in this method for a variety of reasons which have been discussed elsewhere on the message board.
When I was in school the instructor before driving a staff out word just weaken the rivet a very tiny bit. In other words you put the balance in the lathe and just took the tiniest a bit of material off the rivet.
Then we end up with lots of variations like Rolex, Elgin and I believe Hamilton all of made balance staffs that are designed to fracture. But not all of their balance staffs were designed that way. So basically when you go to drive a staff out if it does not want to come out with a minimal amount of force then you should use a lathe. Then depends upon your preference either cut the hub or the rivet as driving a staff out that does not want to come out is usually not in your best interest at all.
It will depend upon what your balance wheel is made of? In other words as long as your balance wheel is not made out of steel you can use alum to dissolve the staff out.
Well, fortunately, on this friendly forum this is limited to a friendly exchange of views! This is how we learn and keep it enjoyable. 👍
I passed up the chance to buy a Molfres tool 2 years ago......bigggg mistake ,I've never seen one since.... think it was only up for 120 quid.   The better punching out methods such as a platax tool, unruh-max and K&D staff removal tools rely on keeping the balance wheel tight down so the staff pops out cleaner leaving less damage to a non steel balance  wheel.....still not as good as cutting away the hub or dissolving the staff.
Usually caseback usually 😅, quite funny to see the occasional disagreement raise in temperature....cant help but think to myself ' grow the hell up, we're supposed to be adults ' 😅
Much worse carryings on with the facebook groups , some members get so petty over there. Tbf some of it is due to language barriers and non native English speakers not fully grasping how to put their point across, we definitely have to make allowances for some folk.
Edited by Neverenoughwatches
Just been diagnosed with dyslexia....as if i never knew 😄
Funny this discussion - already cleared to the utmost detail - gets started again and again by newer members who don‘t know about it.
Surprising that long time members get tired of repeating discussion and reasons?
I will just repeat this link.
Frank
Omg. Did not want to stir up this much discussion! I thought that I start small in the newbie sections to not get to embarrassed 😅. I really appreciate all the support and comments.
Update: I've managed to do the easy part separating the hairspring from the balance without any damage (hopefully 😀). See attached picture
So the next step for me is to buy a tool for the roller to remove that, then look into on how to actually separate the wheel from the staff. I will watch the recommended videos and read into the forums!
One other thing. I'm planning on "harvesting" the roller jewel from another balance to repair the one missing it's jewel. What is the best way of dissolve shellac from the roller jewel and will the roller jewel just slide off nicely when the shellac is dissolved ?
Have you marked the balance to ensure correct positioning of the spring when refitting?
Is it the same balance and/or same size jewel you're harvesting?
Edited by AndyGSi
Yes. It is marked.
Im replacing it with a jewel from another balance from same movement model
31 minutes ago, FredrikP said:
Yes. It is marked.
So if it's the same movement then why aren't you just using that balance or at least the complete roller?
    • Hi Watchrepairtalk, I have some questions about part sourcing I was hoping someone here might be able to help with. I'm working on an FHF 180 movement with a broken balance staff, broken regulator pins, and damaged cap jewels (both top and bottom). Some Googling says that this is similar to other FHF calibers like 150s, 160s, 180s and so on but I can't figure out what the functional difference is between these movements.  Is there any reason I wouldn't be able to acquire a donor FHF 150 or similar (with no shock protection) and use parts from that or would it be smarter to source replacements individually? Also are there any sources someone could recommend to get bulk cap jewels like this? Thank you for the help!
    • Hello and welcome to the WRT forum.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • Use a Portwest Howie lab coat. They are the biological type so they have tapped cuffs so you don't end up getting the loose cuffs of normal lab coats catching everything.
    • Some of the Chinese tools ae great and can be purchased at a fraction of the price of Swiss ones, some are complete garbage and some I'm convinced are coming out the same factory as the branded ones.
