I have just (re)finished a service on an old Wittnauer 10S that I had previously had problems with knocking due to an over-powered replacement mainspring.  I replaced that with the correct Dennison sized mainspring (shipped from from Boston MA to Australia in 2 weeks!).  Solved the problem with knocking and brought the amplitude up a decent amount compared to the old set mainspring which was delivering about 200 degrees.
Testing it on the timegrapher, I find the following:
Dial Up and Dial Down have a minimal delta rate of 7 secs/ day, all of the vertical positions have a delta rate of 13 secs/ day - not bad for an 70-80 year old movement but the total delta rate is 62 secs per day with a big difference in performance between the horizontal positions and the vertical.
What could be causing this difference between horizontal and vertical and what can I reasonably do to reduce it?
6 minutes ago, Nucejoe said:
BE is high.
 Did you adjust the  hairspring-boot?  when regulating ?
I haven't touched any regulation yet, I wanted to see if I could bring the vertical positions closer to the horizontal before playing around with the regulator. It has a fixed stud carrier, so I will have to rotate the collet to get the beat error right.
I did adjust the hairspring boot when I removed the balance from the cock.  I think I returned it back to its centre position when I reinstalled the balance.  I can see the hairspring vibrating between the pin and the boot with what looks like a minimal gap.  The regulator pin looks upright as well.
Now You need to close the distance (boot) between the regulator pins as much as possible. This means the spring to be constantly touching the pin and boot, with no free play, but still the regulator to be able to move without grabbing the spring
I will take a look at it and see it can be closed up slightly by turning the boot more. Should I tweak the regulator pin closer to the boot (or will this have an impact on the dial up / dial down positions if the pin gets out of parallel?)
Turning the boot will not help. You need to bend the pin towards the boot. This doesn't mean that the pin will not be parallel to the boot any more - You can bend the pin more where it gets out of the regulator and bend it back little bit further, so it will be closer and the same time parallel. But being 'parallel' or not doesn't matter any more if there will be no free play of the hairspring. Closing the gap will make slight change in rate - the movement will start working a little faster. It will affect the vertical positions more than horizontal positions, so this is the effect needed.
I would get the horizonal positions regulated to their best time rate and then test again.
A gap of half a hairspring width either side of it is generally considered as good with non overcoil springs. But as Nev says as close as possible without trapping the spring so you can regulate without damaging the hairspring.  With old watches that have blued steel springs that are affected by temperature change, having the regulation pins too tight may not allow them to vary their length.
    • Hello and welcome to the WRT forum.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • Use a Portwest Howie lab coat. They are the biological type so they have tapped cuffs so you don't end up getting the loose cuffs of normal lab coats catching everything.
    • Some of the Chinese tools ae great and can be purchased at a fraction of the price of Swiss ones, some are complete garbage and some I'm convinced are coming out the same factory as the branded ones.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
