Hi all, I live in the UK and have been looking at buying a vintage watch cleaning machine.  A certain online auction site has a few for sale but the asking prices for ones in the UK seem extortionate compared to others offered from abroad.  My question is, if I purchased one from abroad and had it rewired, would the components such as motors and all be able to operate with the UK 240v network?  Even the UK ones for sale recommend a rewire “for safety” so I wonder if these have already been sourced from abroad and have just had a UK plug installed.  The machines I have seen so far are L&R and Elma models.  I know Brenray and National machines are british made so should be fine.
Edited by Bigjay
  • Bigjay changed the title to Help with Buying Vintage Cleaning Machines
Just found this on google. There are a few on here I'm sure will be able to help you more than me. This is googles answer
If the input range includes 230 which is the common UK voltage as well as the 120 which is common in the US then it will work. It also needs to work on both 50 and 60 Hz to work in the US and UK
To add to what OH has provided, if you are buying from Europe it will likely be 220-240V 50Hz same as here in the UK. North American or Japanese machines are more usually 110V 60Hz and would likely need either a transformer or replacement motor. By the nature of these machines being vintage personally I would rewire as a matter of course, insulation deteriates over time and a lot of the older machines were not necessarily earthed properly or indeed at all.
Tom
11 hours ago, Bigjay said:
rewire “for safety”
for terminology your ending up with two separate things that ideally both have to be done possibly.
vintage
vintage wood main vintage wiring and vintage wiring as a problem of not being safe for variety of reasons. So anything vintage with electricity the wiring needs to be verified that it's still functionally correct and not going to burn your house down for instance. So typically people rewire a functional machine to make sure the wiring is suitable. So basically it's not so much the wire itself it's the insulation disintegrates so that needs to be dealt with which would be called rewired.
then just to make sure I get my numbers right quick search and I got the link below. As you can see the power coming out of wherever it comes out of is different depending upon where you live. So in the US it's considered to be 220 V at 60 cycles.in the United Kingdom it's 230 V at 50 cycles.  fortunately if you look at most of Europe 230 and other places 120 so yes a lot of equipment can be rewired because it was designed to work in either location. His wife you look at modern power supplies for all of our electronic stuff they will usually say between 100 and some voltage as there designed to have just about everything.
Oh and purchasing a vintage cleaning machines or for that matter new cleaning machines whoever packages up and ships to you should be aware of cleaning machines in general are heavy and glass does not like to be bumped by heavy objects. As a really interesting video on YouTube or someone purchased a brand-new Elma machine and Elma didn't seem to grasp anymore or at the time failed to grasp that they didn't package their jars appropriately and they came disintegrated and the machine of course was damaged. Which wouldn't happen if things were properly packaged. As a brings up the problem of vintage machines were they ideally should almost send the jars separate from the machine to keep the jars from disintegrating.
https://www.generatorsource.com/Voltages_and_Hz_by_Country.aspx
Although most homes and businesses in the US have 220V/60Hz power available for large, fixed appliances and tools you will find that portable tools such as watch cleaning machines sold here will almost all be wired for 120V/60Hz, including the vintage L&R machines.  They can be used on a higher mains power by using a step-down voltage transformer and the 50 to 60Hz mismatch isn't a major issue for components such as the universal motor and power resistor (heater).
2 hours ago, Geotex said:
e 220V/60Hz power
thank you for pointing out a technical mistake. yes the standard voltage for standard things in the US is 120.
Thanks John.  I think the point i was making was that sellers of these vintage machines in the uk that have been using them already seem to want to charge extortionate prices and then state the wiring should be re-wired or refurbished.  Obviously my issue would be if they have been using the machine in the UK then it would be fair to assume that the wiring should be up to UK spec (as they wouldn’t want to burn their own house down) so why ask such high prices for a machine that essentially needs major work(if they are claiming it need a rewire or refurbishment).
So, I then look at the overseas market where prices are so much cheaper (lets ignore import taxes for now and just focus on the value of the machine) and I wondered if those machines could be converted to be used on the UK network.  I have to honest, the whole explanation of 50hz/60hz  or cycles means nothing to me as have no idea what any of it means in reality.  Just wanted to know if I bought a cheaper like for like machine from overseas, could I get it to run safely on UK power supply?
Thank you, that is very helpful.
Tom
Thanks Tom, that makes sense.
I think that it's just an indemnity clause in case of any mishap. 🤣
Edited by HectorLooi
Typo
I think you are probably right!  👍🏻
Because they can, watch repair addicts with plenty of cash....will want a traditional machine for just that fact alone and repair it or have it repaired. My view is to build something simple that performs as well for a very small fraction of the cost of a vintage machine that might need repair when you get it and in the future.
With patience and some time investment you can have an old cleaner for much less than many sell for in working condition. I have two functioning L&R "vintage" machines but I approached it the same way I do watch repair - avoiding the most trendy models and watching for bargains by piecing together various used lots that had useable parts that could be cobbled together. The really old open-frame first generation units (painted silver or gold, not black) used mixer motors that don't reverse (low resale) but I've rewired them so that they now will. For my very old "Master" I've also set it up with a wiring breakout box that includes auto-switching so it has the Forward <-> Auto Cycle switch of the black base units that get top dollar. I've probably made eight or so Ebay purchases to put together everything, but it was enjoyable. You may end up with a Frankencleaner, but it's put together with quality aged components just like the watches we like working on. However, I didn't have to buy any specialty tools, so that is one downside compared to spending that time on watch repair.
I would go for a DIY kit cleaner instead of a vintage watch cleaner . If you google diy watch cleaner you will find a few , print the parts on a 3d printer or have the parts printed for you , get the hardware from Ali express and you end up with a better machine for half the price and it’s very satisfying building it.
    • Righty ho, I re-serviced the chrono module and got a reasonable result with minimal loss of amplitude when not running the chrono and about 30 degrees loss when running. Great. The problem is now that the chrono (and movement) stops running after about a minute or so, a tap on the watch starts it running again. No issues with the movement running when the chrono is stopped. Going to service it yet again, obviously some residual issues with friction in the chrono module (Very frustrating - I wish there was some way of testing it as I go!) I also seem to have a problem with the cannon pinion where the movement is running continuously (with the chrono stopped) but it's losing significant time / stopping. This is one of those two piece ETA style with a driving wheel pressed over the cannon pinion, obviously arranged for driving the chrono module. I had no issues with this prior to service and just added a small amount of grease between the driving wheel and the centre cannon pinion as the technical guide required. What's the best way of tightening these up? I would like to replace it but I guess this is going to be hard to find as it is dedicated to the DD chrono movement.
    • He uses the micrometer cap, but he leaves the spring out (you can see that in the video). If you leave the spring in, the spindle will move up as well (as shown by @Knebo).
    • Seems like he doesn't have the micrometer cap  attached to the spindle so he can only push down but cannot pull up? If the cap screws into the spindle I guess you don't need the spring? I only have a "normal" Seitz so I really have no idea.
    • Do you have a part number for the bearing shim lock tool?
    • Yes in my opinion the 3/4HP is plenty but it’s your decision & yes it does come with speed control but foot operation so my reason for changing to potentiometer was because my leg shakes so it was like me revving the lathe & anyway I prefer to set the speed. I & a few others that I recommended the motor to run a Pultra 10mm lathe so if you have a 6 or 8mm B & L then it will be plenty, if you have seen any of my videos you will have seen that when using a graver I run quite slow without any problems. Dell
